If it really is the start/power button it can be replaced
https://www.walmart.com/ip/AGM73610705-For-LG-Washing-Machine-Power-Button/133456714?wmlspartner=wlpa&selectedSellerId=1672&adid=22222222227047958931&wmlspartner=wmtlabs&wl0=&wl1=g&wl2=t&wl3=146916351971&wl4=aud-481962823846:pla-257941805513&wl5=9031999&wl6=&wl7=&wl8=&wl9=pla&wl10=112562764&wl11=online&wl12=133456714&wl13=&veh=sem&gclid=CjwKCAiAyMHhBRBIEiwAkGN6fJ3KLDXaZysGz0kU99kGuRWOiCCruLe_ONsjWJEmad3rknVGQ_ZabRoC-7QQAvD_BwE
Testimonial: "Thanks,but most probably problem in PCB panel 6870EC9286D(MEGA-Refresh-PJT)"
Most likely will have to replace the control board
SOURCE: LG Intello washing machine, model: WD12235 Front Load
Why dont you people read the user's manual? You wil learn abt your machine, to a certain extent. Try "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds. Works for other machines...............And please rate me if helped................
SOURCE: LG intellowasher (front-loading washing machine) is starting to squeak.
I suggest u buy another washing machine. This one's had it!
SOURCE: cant rurn on my my washing machine
Have you tried a simple reset, by unplugging, waiting several minutes and then replugging it in? Is it plugged into a gfi outlet? is the little red button pushed in? It should be. It hasn't flipped a breaker off has it?
SOURCE: LG front load washing machine will not spin
I am having the same problem with my washer. Go to this web site below it has a free troubleshooting guide. I narrowed my washer machine down to two parts. Stator assy or Main PWB assy.
http://136.166.4.200/contents/Laundry/WM2042/WM2042xx_Service_Manual.pdf
SOURCE: Lg tromm front loading washing machine has
Yes the system is cloghed. Pull the detergent drawer out and clean the drawers housing. try using some bleach. It allways helps.
BE ADVICED: after using bleach run quick wash cycle on without any load, it's just to get rid of all bleech remains and not to damage your clothes
Update me about your progress
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
OVER SUDDSING
