Hi All, from a bit of invertigation and learning about different types of e-motors. the issue is with the spooling or coils of the motor. This particular type has a start coil and a run coil. in this particular case the run coil which powers up the pump to full RPM was defect. New pump instaled.
SOURCE: Frig stopped cooling. Bad condensor Fan Motor.
sounds like a bad thermostat,that tells unit when to kick on and off.
SOURCE: My 91 Accord has failed a total of four times in
did you chsnge the 02 sensors by any chance?usually if you have a bad catalyc converter is becauce a bad 02 sensor that cauces that to go bad.
SOURCE: HVAC condensor fan won't start-will run if spun.
See if it has any oil ports on the motor, if it has them they should be yellow and they are a plug.
If it does not have any oil ports, you are bqasically down to replacing the motor.
SOURCE: condensor fan fuse keeps blowing
Dear friend, without knowing exact problem changing parts is not advisable. With your statement I could understand that condenser coil full of dirty- clean it. And then check capacitor for compressor by reading amps. If amps gradually increase capacitor to be replaced. And also wiring for not short circuited.
SOURCE: window AC unit, Hi speed doesn't work. AC motor
It is possible that the high speed went out on the motor but I doubt that. I would replace the switch and see if that takes care of your problem.Good luck and thank you
