Televison & Video Logo
A
Anonymous Posted on Jan 05, 2019
Akai led tv AKLT40-D07SM model I want Tv remote code sir Plase
Level 3:
Top Expert:
  • Akai Master 76,851 Answers
  • Posted on Jan 05, 2019
Akai Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14986955
Points
237762
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; to which you want set-up codes; in the "Search box at the top right of the display window" to get gathered related posts.
{View the site in web view by Mobile or a desktop to see the search box. Mobile view has no search box.}/
5 Related Answers
Anonymous
  • Posted on Dec 30, 2008
SOURCE: remote that came with tv wont work
I stumbled across this page while the owner's manual for my remote was lost. I've now found the manual (after not having any luck finding the solution on the web)!
The AKAI KC02-D2 remote operates my AKAI PDP42Z5TA 42" Plasma HD Television. It may work with others as well, but that's the TV I use it for. If the batteries are removed (or dead) for a while, it will lose its programming. Here's how to reprogram it.
AKAI = 231, 218, 221, 222, 225, 226, 227, 228
1. Turn on the Device you want to program. The remote can be programmed by pressing the 3 Digit Brand Code number listed in the code table of this programming guide. If multiple codes are listed, you may have to enter several codes to complete the steps below. (Note: For programming the VCR, a tape must be loaded/inserted first.) If your Brand is not listed, please use the Manual Search menthod or Auto Search method (Section C & D below).
2. Press and hold the SET button for about 3 seconds until the current Device LED lights (TV, VCR, DVD, STB.), then release the SET button.
3. Press the device button you want to program (TV, VCR, DVD, STB.) then the selected Device LED will light on.
4. Enter the 3 Digit Brand Code for the desired Device. For example, enter "2" "1" "8" for AKAI TV. When entering each digit, the Device LED will flash one time. After all 3 digit numbers are entered, the Device LED will turn off. If the code is not valid, the Device LED will flash three times then turn off. Check the code list and repeat from the above step 2.
(*The manual contains a huge list of 3-digit codes for various devices. If you're looking for a specific one, just ask.)
Anonymous
  • Posted on Mar 16, 2009
SOURCE: Akai tv remotes
I purchased a HARMONY remote ( logitech ) and it worked for the AKAI PDP4273M .
Anonymous
  • Posted on Mar 17, 2009
SOURCE: Remote Control Programming
GE Universal remote only $12.00 at Target works on my Akai LCD HDTV, this remote also has learning capability but the third code under Akai worked!!!
Anonymous
  • 10 Answers
  • Posted on May 02, 2009
SOURCE: code remote akai pt46dl10
had same problem tried all kinds of universal remotes but none were compatible look online and found only logitech Harmony® 550 Advanced Universal Remote is compatible with this model akai pt46dl10 bought one now works fine and was able to reset my lamp timer with it as i just replaced it paid $65 on craigslist for remote good luck
budlight2k
  • 20 Answers
  • Posted on May 30, 2010
SOURCE: I need codes to program direct tv remote (20.0IR EchoStar 158926)
Press 'Menu'
Scroll to 'Customer support' and Press Select
When the application loads you'll see the codes menu.
Need Codes for Akai television using Stang F-2100 universal remote.
It is 2023, no one uses Universal Remotes these days!
https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote
Codes are to the television maker, they don't change depending on the make of remote used. But as I said, no one buys universals, you buy a copy remote made for the make model you have.
Akai TV universal remote control codes (3, 4 and 5 digit)
eliztech.com https://www.eliztech.com > remotes > codelists > akai-t...
Universal remote codes for Akai TV sets - 3 digit, 4 digit and 5 digit codes. ... Mixed Akai TV codes from nine brands of universal remote controls.
3, 4, & 5 Digit Akai TV Remote Codes with Programming Guide
smarttvremoteapp.com https://smarttvremoteapp.com > akai-tv-remote-codes
Akai TV Remote Codes for DirecTV ; 11385, 11692, 11935, 12232 ; 10765, 10812, 10030, 10098 ; 10672, 11676, 11689, 11690.
Universal Remote Codes for... · ‎Akai TV Remote Codes for Dish
What is the code of Akai led tv how to connect re-300e+ remote to this tv
The applicable code(s) would be in the remote control, if it is compatible.
3helpful
I have a AKAI LCT3701AD 37 inch TV don't have the original remote control but bought a universal remote control but is not working Why?
YOU WILL STILL NEED TO PROGRAM THE NEW REMOTE FROM THE MANUAL THAT CAME WITH THE REMOTE. NORMALLY THIER ARE TWO WAYS TO PROGRAM A REMOTE EITHER MANUALLY OR TO DO IT AUTOMATICALLY. YES THE ORIGIONAL REMOTE IS ALREADY SET UP FOR YOUR MODEL OF TV BUT WITH THAT SAID TRY TO PROGRAM IT BY BOTH PARTS OF THE MANUAL. i AM USING A 55 INCH SMART TV AND HAVE DONE THIS AND ON OTHER SMART TV'S. ALSO YOU CAN GO TO THE WEBSITE OF THE REMOTE THAT YOU PURCHASE AND LOOK FOR VIDEOS ON HOW TO SET IT UP. IF YOU NEED MORE HELP LET SOMEONE HERE KNOW. GOOD LUCK.
1helpful
Will any universal remote work with my Akai Model CFT2790?
Hello there
YES !!!!
Do you simply HAVE to have UNIVERSAL Remote?
For this TV the correct remote is here for 10 American dollars. http://www.replacementremotes.com/AKAI/Buy-10111J-AA5910111J-TV-Remote-Control.html
On the other hand if you must have a universal remote, then it WILL work with remote code for Akai which is 002; See the instructions with the new Universal remote.
Obtained from here http://en.kioskea.net/faq/281-codes-for-universal-remotes#universal-remote-codes-by-brands
Akai ct-2202 tv turns on but no picture when i connect cable tv wire, cable oprator said me your akai tv tuner problum Please solve my problum Sanjeev Kumar Delhi, India
sir . i need akai ct2202 remote control model no. i lost my remote in transit and without it i'm not able to use the tv. my mail id : [email protected] pls help. thanks & regard's. V.SRIKUMAR
I can't program my remote control for TV Sony. Due to I lost the manual. Can you help me plase? Remote control RC 23 Direct tv.
try this: 10000 findmorecodesoff.gif itworks2.gif
Setup Instructions
  • Set the "Mode Switch" to TV.
  • Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
  • Enter the 5 digit Code above.
  • Try your new code and tell us how it worked!
  • 17helpful
    Remote that came with tv wont work
    Akai tv remotes
    Top Akai Televison & Video Experts
    Grand Canyon Tech
    Grand Canyon Tech
    matt martin
    matt martin
    Accurate TV Repair...
    Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
