SOURCE: Scanner Problem HP 1005
for resolve this error you should only change the flatbed scanner wiht a new one. this error is hardwere issue.
by.
M.R.Atyabi
SOURCE: SCANNER ERROR 12
it is a physical brocken piece that supports scanner mechanism.
if you open that plate /scanner mechanism and if you drill that plastic sheet and try some manufactureed alluminium or metal projection and place it in the hole drilled by you and put washer and screew so that that supports ;the scanner mechanism and your scanner /printer works . the scanner mechanism may costs you around 3,000-00 rupees.
SOURCE: HP Laserjet M1005 MFP scanner and printer shows
The job that you are trying to print is too complex for the printer. Add more memory. Or simplify the job.
SOURCE: driver for HP laserjet M1005 MFP printer for
Here is the Driver and Software download page for your HP Laser Jet M1005 at hp.com:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=1839459&taskId=135&prodTypeId=18972&prodSeriesId=1839458&lang=en&cc=us
1. After you click on the link above, select the language for your printer driver from the drop down menu.
2. Select the version of Windows 7 you have. (either 32- bit or 64-bit)
3. Save the file to a new folder on your desktop. (It will be easy to locate after downloading it)
4. I would also download the Windows 7 Print Driver - Installation Instructions save it to the folder on your desktop and read it before you install the printer driver.
