Your owners should have that information. Should be a bleeder valve around the fuel filter. If not crack open the injector line and crank until fluid comes out. Do not make a mess.
it already has glo plugs to help starting
check that they are working
diesels need a fast cranking speed so make sure that the battery is in top condition
have a compression test done to check for correct compression pressures
have the injectors serviced because if they squirt instead of atomize then it make starting difficult
what fuel is it as it can be air in a diesel so you have to bleed it. or you have damaged your fuel pump in a gas car in the uk we call that a petrol car .you pump needs fuel to cool it.
you have to vent the air in the injection pump crack the injector pipes and crank the engine till fuel come out then re secure the pipes it will start then
Agree with with previous answer. Check your fuel filter & make sure it's full of fuel, usually the problem if the motor wont start after running it out of fuel.
All kinds of manuals are available here
https://big-manuals.com/search?q=new+hol...
