SOURCE: lg led tv backlight
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Hi, checking user manual there's no soft reset option so maybe the main board is faulty too, usually when there's a damage by lighting in power supply this also reaches the main board since they aren't electrically isolated.
SOURCE: When testin a power supply or led board on tv do i test dc or ac with multimeter?
Your power supply board is working if you get audio and imgaes.
You test AC only the AC side of the transformer before the Rectifier Diodes. Everything after the Diodes will be in DC.
did you get to see any spec of backlight as shown in
LCD LED TV Repair No Image Blank Black Screen Flashlight Test How to Fix...
SOURCE: Samsung TV
If you see a picture with the flashlight you can rule out the T-Con board. It's working. So the led driver board is the problem. TV Parts Universal TV Stands DLP Chips ShopJimmy Go here for replacement parts.
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
