The hdmi cord must be connected to your tv and the other device. Your tv should recognize this immediately. When plugging in new cords. Unplug tv first. This will help it to reset itself.
SOURCE: How to connect BLU-RAY DVD player to Pioneer Plasma TV via HDMI
The best possible solution to your problem is :
Connect your blu ray player directly to the HDMI input of you Plasma and watch HD video....
and connect the 5.1/7.1 sound thru the optical or the coaxial link directly to your AVR 3805.
You will not loose anything on the Blu-Ray.
The sound is best processsed by the AVR3805, while the video, which is the real upgrade (BluRay) in terms of resolution of picture would be processed by your plasma.
Connect and Enjoy
SOURCE: i connected my hp laptop to my pioneer plasma via
Hello. You have to go into your Display Settings, in your HP Laptop, and chose the Dual Screen/Monitor Setting & make sure you check the "Extend my Windows Desktop onto this Monitor" Box. If you are trying to view your Internet Browser on your TV - you will need to Click on and Drag your Browser to the Right... of off your Laptop Screen and onto your TV Screen. This will take care of your problem!
SOURCE: Picture on screen is narrow and I cannot select normal view
use menue button on tv if this does not work change main board in tv
SOURCE: how do I connect my
If the tv has normal stereo outputs, you will use those. if it only has a digital output, your best option will be to buy a new receiver.
SOURCE: displays error code cec100.
CEC100 is a system by which many devices connected via HDMI may control one another. The error message indicates that one or more devices do not support this protocol. In this case, I venture a guess that the error message is appearing because your TV does not support the CEC100 protocol. It should not prevent the machine from playing, it is simply is notifying you of a communication failure.
