SOURCE: Need a cap gasket for a Rowenta DG5030
I showed the part to my husband. He took it to our local Aubuchon Hardware and bought the same size gasket for 59 cents. I just tested it out and my iron works just fine now. The one from the hardware store is black, vs the Rowenta one which is green. Who cares what the color is, no one sees it anyway. However, if you have to send your machine for repair for something else, they may not honor your warranty as you've now added after-market parts. Just thought I mention that. Good luck.
SOURCE: Rowenta Steam Iron DG5030; Iron drips water
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
SOURCE: my rowenta dg5030 is leaking at the cap
My question is what is Rowenta doing about the gasket problem. Where is the replacement.
SOURCE: do you know where I
Hi there.
You can buy parts for your steam iron at http://www.rowentausa.com
Regards.
Screws may hold the shell together but the halves are usually clipped together by hooks around the edge of the shell to discourage would be 'electricians' from doing home repairs. Once you've removed the screws and the body held by the screws doesn't come apart, look for a point where you can insert a screw driver in it to pry the body part out. If you can't do that, then don't do it. best thing to do is take it to a repair agent. At least it's safer.
