around 120 psi with no more than 10% difference between adjacent cylinders 120--120--110-110 indicates a head gasket or 120-100-100-120 is head gasket. test is done cold with the throttle held wide open and all plugs out.. Next squirt oil from an oil can (3to 4 pumps) into each cylinder and retest Pressure should go up indicating good rings. If it doesn't change up in each cylinder the cylinder will have possibly a broken ring or scored bore allowing the oil to be blown into the sump
this is how you disable autofocus for this camera, first set cam to camera mode.using touch panel screen:
1.press FN to display PAGE1
2.press FOCUS
3.select and press MANUAL
4.select and press (icon of person) when subject is too close to focus on or (icon of a mountain) when recording distant subject
5.press (return arrow w/OK) to return to PAGE1
hope this info helps.tnx:)
Most finders focus by either turning the lens, or the eyepiece portion of the finder. Look through the eyepiece at a distant object and try turning one or the other as described above.
You can buy a USB to USB mini cable at almost any store with PC accessories, even Walmart. Buy a high quality one since the drive is powered from the USB 2.0 port. Good Luck
