SOURCE: prewash always flashing
yes i had a similar problem the prewash light kept coming on mid wash cycle and eventually stopped taking in the water just bypassing it straight to outlet without filling machine. i found if you remove the pump at the rear of machine and disconnect hoses there was a build of lets say deposits leading to a sensor through a opaque plastic connector to the top of machine . after cleaning the hoses thoroughly and removing all the crud machine worked as it should do, hope this helps
SOURCE: error code on bosch washing
HI
Most washing machine timers are digital or mechanical. The timer controls most of the operations of the washer: water level, tub filling and emptying, length of cycles, and cycle setting sequences. For this reason, any repairs to the timer should be made by a professional service person. However, there are a couple of checks you can make when you suspect the timer is faulty -- you may be able to install a new timer yourself.
Step 1: Unplug the washer. To access the timer, remove the control knobs and the panel that covers the controls. This may be a front panel, or access may be through a panel at the back of the unit. Carefully examine the wires that connect the timer to the other parts of the washer. If the wires are loose or disconnected, try pushing them into position; they usually fit into their terminals like plugs. Use long-nosed pliers to avoid breaking the wire connections -- never pull a wire by hand.
Step 2: To test the timer, use a VOM set to the RX1 scale. Disconnect the power leads to the timer and clip one probe of the VOM to each lead. The VOM should read zero if the timer is working. Since the timer is a multiple switch, turn it through its cycle and test each pair of terminals in turn. The meter should read zero at all of these points. If one or more readings are above zero, the timer is faulty and should be replaced.
Step 3: To replace the timer, unscrew and disconnect the old one. Install a new timer made specifically for the washing machine. If there are many wires on the timer, have a helper hold the new timer next to the old one as you work. Disconnect the old wires one at a time, connecting each corresponding new wire as you work, to make sure the connections are properly made. Or, draw a diagram showing the connections before removing the old timer. After all the wires are connected, check the connections again for correctness and screw the timer assembly into place.
SOURCE: our clean light flashes 7 times pauses and flashes
This machine was made by Whirlpool and the flashing clean light is a common error code for them.If
the clean light is the one flashing then your dishwasher could have a
heater circuit problem (depending on the age) or this could simply just
be water colder than it is used to getting.
Repeatedly press the Heated Dry and Hi-Temp Wash(scrub) which ever yours has until all the LED lights come on, press cancel twice and
try the dishwasher again making sure to run the water at the kitchen
sink till it is hot before starting the dishwasher, if this trips and
locks you have a problem with the heating element, or temp sensor.
Press
the heated dry button followed by the normal cycle button, and then
repeat once. You should see all of the lights come on for a second or
two, and then the dishwasher will work again.
If you haven't
already, take a look under the kick plate in front to see if there is a
schematic tucked in there somewhere. Whirlpool has put their
diagnostics for specific models on these.
I don't have the specific repair manual for you model.
So, if the above combination does not work here are two more that have worked for me.
HiTemp Wash + Air Dry + HiTemp Wash + Air Dry in less than 5 sec
or
Hi Temp Scrub/Scour + Air Dry + Hi Temp Scrub/Scour + Air Dry in less than 5 sec
Let me know, if you need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
SOURCE: Clean light flashes 7 times
Hello there again
here is some more information for you this is directly from the manufacture
tbirdfan1 says:
A
clean indicator that flashes/blinks 7 times and then repeats, indicates
a problem in the dishwasher which should be investigated and not just
the control 'reset'! That is why the control will not let the
dishwasher start once such a condition is de
tbirdfan1 says:
detected
tbirdfan1 says:
If
the dishwasher's electronic control doesn't detect a water temperature
increase during the main wash cycle, that symptom can occur. No water
temperature increase could be caused by a problem in the heater
element,
tbirdfan1 says:
its in-line thermostat, the related wiring or a problem in the electronic control.
tbirdfan1 says:
It
is also possible just the washer not spraying properly (possibly from
blockage in the filter or problem in the pump), the dishwasher not
filling sufficiently or draining prematurely or even a problem in the
door latching mechanism's switch(es) cou
tbirdfan1 says:
could cause it
tbirdfan1 says:
the
error display may have to be cleared from the control manually. That
can usually be done by putting the unit into diagnostic mode by
pressing the key sequence 'Heated Dry, Normal, Heated Dry, Normal' and
then pressing cancel.
SOURCE: need a user guide for bosch wff 2000 english
to download a User's Guide try going to www.audiobosch.com or www.bosch.com. If not try getting contact information for Customer Support. Try e-mailing Customer Support for a download or a download link. Also you may be able to call them if a phone number is given.
My EWD1477 was doing this a year ago and I fixed it. Then it started
doing it again a month ago and I seem to have cleared it again.
Firstly, remove the drain hose from where it is inserted into a laundry
sink hole to make sure it is not blocked or sealed in with sludge.
Secondly, make sure the machine is empty of water and clothes and then turn
the machine to off with the Program Selector Dial. Then turn off the power at
the socket and remove the power plug and leave for five minutes.
Step 1: put the plug back in and turn the power back on.
Step 2: turn the selector switch to the right (Whites/Intensive). The green light of the Start/Pause button
should be flashing and the green lights on for Prewash/wash, Rinses and
Spinning. Don't press any other buttons or change any other settings.
Step 3: press the Start/Pause button and wait for the machine to empty
any excess water. Press it again immediately after you hear water flowing into
the machine OR two audible clicks. The machine is now in pause mode with the
green light of the Start/Pause button flashing. Only the green light on the Prewash/Wash
button should be on. Leave it in pause mode for 30 minutes and then press the Start/Pause
button to recommence the cycle.
Step 4: If the Start/Pause button begins flashing, water stops flowing
into the machine and the three green lights mentioned above are back on, turn
the Program Selector Dial back to off, wait 10 seconds, and repeat the process
above.
Step 5: If when you then turn the Program Selector Dial to
Whites/Intensive and hear the two audible clicks, immediately press the
Start/Pause button to set the machine in pause mode. Wait 30 minutes. Then
press the Start/Pause button to recommence the cycle.
Hopefully the cycle will run without a problem.
