SOURCE: Kitchen Aid dishwasher Child lock light on and dishwasher will not start.
if your unable to unlock the "childlock" by holding down the button, then it woud seem that theres a problem with the user interface itself
SOURCE: I cannot unlock the controls on the panel
Try turning the circuit breaker off for 30 minutes. Then turn back on and see. If it keeps locking you may need new control console. Hope this helps.
SOURCE: Oven went dead in self clean mode and the door
Unplugged the stove and turn off the gas.Take the back off the oven and replace the thermostat. It's super easy. Before you buy the part call kitchen aid... this is a known problem. They will say the parts are not free and try to give you a discount. But if you continue to argue , they'll send it for free.
SOURCE: My dishwasher DU1050 is stuck on Lock and I've
Hi! cccole
Dishwasher may be in bind. remove kick plate and make sure adjusters are not putting case in a twist, or pressing unit to tight to top of cabinets.
InMrFixIt.
SOURCE: My dishwasher has locked all of the control
Hello, Thank You for using FixYa. I will be helping you today.Try holding it longer and if that dont work you might have a bad touch membrane.
Thank You and please rate my answer if it was helpful..
Thank you for your post, friend!
I see that you are having trouble with the control lock feature on your Frigidaire dishwasher. I would be happy to assist you with unlocking the dishwasher. In order to provide you accurate assistance I would need your model number. You can locate the serial tag (which lists your model number) on the inside left hand wall of your dishwasher. I look forward to helping you out. -Matt
Hello Ray E. Weaver - Sounds like the Child Lock option may have been selected. This is a safety feature that allows you to lock and unlock the controls to keep children from interfering with the wash cycle etc. Press and hold the AIR DRY pad button for 3 seconds while the door is latched. This should unlock the control pad for you, light goes out and the unit will display the last cycle ran. However, if it does not, try resetting the unit by unplugging it for flipping the household circuit breaker off. Wait approximately ten minutes and turn the unit back on. However, if it proves to be ineffective I recommend contacting a professional to assist further. The dishwasher may possibly have faulty door lock switch.
Hello
& Welcome to FixYa
Press
and Hold the HEATED DRY/NO HEAT DRY button for 20 seconds to unlock the
control. Please get back to me if you have any other questions.
Kevin
