Vacuums Logo
Jerry Mikkelsen Posted on Jan 03, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The pickup bush will not turn, Is their a drive belt,
Matthew Minton
Level 2:
New Friend:
  • Expert 58 Answers
  • Posted on Jan 03, 2019
Matthew Minton
Expert
Level 2:
New Friend:
Answers
58
Questions
Helped
32143
Points
160
Yes there's a belt you got to flip it over get a screw driver and pull out the two screws and then take the cover off and you can get to the belt
Just stopped working. battery ok.
Either the belt came off or the bushings went out of the motor. 9 out of ten times, its the belt. Check to make certain the belt is on the gear that drives the motor or is not worn or stretched. If that is ok, then take apart the motor and see if the bushings are cracked or broken. You can get them for $1
Nov 10, 2017 • Vacuums
Hoover hard to push and brush light on
Bush is not turning and belt has snapped. Order replacement on Amazon. Loosen retainer screws on back of shell.. open remove belt and align and replace belt on bush bar and motor spindle. Done.
Bissell carpet steam cleaner> bushes do not turn
There is a replaceable belt that drives the brushes.
The roller will not turn fast enough and it starts to smell like it is burning
The smell is probably a rubber drive belt slipping on the bar. Sounds like it needs a thorough cleaning. Look on the bottom of the machine for a way to open access to the belt and bar. Take the bar out and pay special attention to the ends while cleaning. Hair and carpet fibers.
My roller bush won't turn ever time i put a new
1) you need a little tight the belt, with the bolts of motor.
2) you must shure if the belt if NOT large or short( in both cases the rollers will NOT run. can be slip. or too TIGHT. and BRAKE the motor.
3) the motor you must test for brush, switch, or open winding.
4) put a little lube in the extreme of shaft rollers,see by turning at hand if they run of course unplugged the power cord.
God bless you
Jul 23, 2012 • Vacuums
3helpful
After turning on power , brush roller freezes and indicator light turns red
try turning the roller by hand UNPLUG VACUUM FIRST
it should turn very easy, otherwise it is binding
all uprights have this problem eventually
hair and fibers get in roller bushing and seize
luckily disassembling is relatively easy, same procedure as replacing the small belt that drives the roller. Take the extra step and take out the roller slip off bushings and clean everything
have fun
alex
BRUSH WILL NOT TURN
Remove any fibers (hair, carpet thread, etc.) or other trash wound up around the brush bushings. If necessary, disassemble and clean the bushings. This alone may not repair the problem, it is only the cause. After that, check the belt for bad spots - a stalled brush often causes the belt to wear heavily in one spot or break. Replace as needed.
DYSON DC14 While vacuuming the living room, the rotating brush started making an awful loud grinding sound. We opened the intake port, cleaned the brush but to no avail sound still persists once you lower...
Take the bottom plate off and check the belt. Also, rotate the brush by hand - it should turn with only a moderate resistance from the belt, or very little if you take the belt off. If it is hard to turn, or if the belt is stripped-out right where it goes around the roller pulley, one of the roller bushings is stuck. In that case you'll have to remove the roller and clean or replace the roller and bushings.
It's possible that the problem is actually in the blower, but most of the time a roller bushing or a foreign object caught under the roller is the culprit.
Nov 27, 2010 • Vacuums
2answers
Beater? bar doesn't spin
That means that the belt is broken, stretched or worn. You need to change the belt. You can get replacements here:
Replacement Vacuum Belts
Dec 08, 2009 • Vacuums
Not moving
i guess you mean the pickup bar if so sounds like you need a new drive belt
Aug 21, 2009 • Vacuums
Top Vacuums Experts
AskDyson
AskDyson
Anonymous
Are you a Vacuum Expert? Answer questions, earn points and help others
