B
Buggsz Koller Posted on Jan 02, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error code of:0-61000016
Cannot Clear to print anything
Pensivania Pensive
Level 2:
New Friend:
  • Expert 66 Answers
  • Posted on Jan 03, 2019
Pensivania Pensive
Expert
Level 2:
New Friend:
Answers
66
Questions
0
Helped
56915
Points
177
Error message displays on the product. A paper jam might have previously occurred.
How do i clear error code c4154 on bizhub c250
Polygon Motor for the Black Print head LASER is bad, the motor is internal to the print head get a new print head for the black, requires tech to install, clear code bye open closing front door.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
How to clear error code 49.4c18 on HP laserjet 4250
any 49.xxxx codes are related to firmware crash.
the probable cause is a corrupt file in the print queue. remove the printer from the network then after network is disconnected - cycle the power on the machine ( switch off then wait 10 seconds switch back on)
the 49 error will probably clear . if so Clear All print jobs in Print queue on the computerr workstation. then reconnect printer and away you go!
if however the error remains then you will need to Upgrade the firmware or replace the firmare chip/formatter ( unlikely I've only ever replaced one out of thousands of calls for this fault)
1helpful
My printer keeps saying this document failed to print before it prints or half way through the job
When I go to print a document it feeds paper through without printing anything ... my x63 keeps saying clear system error then press clear. ...www.fixyourownprinter.com/forums/inkjet/13953
53helpful
6answers
CANON IR 3300 HAS ERROR CODE: E000002-0000
OK, but first try to clear the error under service mode, then replace fixing film assy, for EU 240V is FG6-6041.
To clear the error:
* 2 8 *
COPIER
FUNCTION
CLEAR
ERR
OK
Turn off and on ( main switch )
If this dont help - replace fixing film assy.
3helpful
2answers
Sharp Z-835 Copier with H3 error code. I understand that this error code indicates ''Overheated Fusing Unit''. Is there anything that I can check or replace so as to get more use from the copier?
Hello sir; It don't need to anything but reset, the procedure as follow; press "clear" 'exposure" "clear" "exposure" then press 14 hit print, it should take care of you, good luck.
Xerox XC1875 U4 Error on Startup
Give this a try. it may clear you code. Use program 14
To enter diagnostics: Turn on the power and within 4 seconds press the following sequence: ‘Clear’, ‘Exposure Mode’, ‘Clear’, ‘Exposure Mode’ (Exposure Mode is the button on the far left). The console will go completely blank.
To enter a code: Select the first part of the code using the copy quantity buttons, followed by the ‘Print’ button, then the second part of the code followed by the ‘Print’ button again.
To exit diagnostics: Press ‘Clear’ repeatedly or turn the power off.
*To clear a fuser code:(14) Enter diagnostics, select ‘14’ followed by ‘Print’… exit diagnostics.
**To Clear a U2 code:(16) Enter diagnostics, select ‘16’ followed by ‘Print’… exit diagnostics.
Error code H3 displayed on Xerox XC1044 Copier
this is the solution:
To enter diagnostics: Turn on the power and within 4 seconds press the following sequence: 'Clear', 'Exposure Mode', 'Clear', 'Exposure Mode' (Exposure Mode is the button on the far left). The console will go completely blank.
To enter a code: Select the first part of the code using the copy quantity buttons, followed by the 'Print' button, then the second part of the code followed by the 'Print' button again.
To exit diagnostics: Press 'Clear' repeatedly or turn the power off.
*To clear a fuser code:(14) Enter diagnostics, select '14' followed by 'Print'... exit diagnostics.
H3 stands for high temperature at the fuser.
k24674
ADMIN Andrew
ADMIN Andrew
