SOURCE: Maytag lse7806ace
After removing the power (easist was to shut breaker off), then replaced fuse just inside upper front left cover area by way of 2 white screws on bottom front panel. Clips secure the top into the horizontial lid panel (which you will also have to remove later if fuse keeps blowing) That worked for a coupe weeks as long as the Cycle Selector dial was always pushed in when you opened/closed the washer lid. Then the the problem returned. Only way out was to partially remove the unit from the wall and remove the lid assembly, which was much easier than first thought. Pictures attached. Tools needed are Phillips screwdriver and Nut drivers to remove the horizontial lid/panel from above the washer tub, and below the timer panel/dryer. Didn't need to remove the angled cover below dryer as Washer Door lid assembly is wholly below. Just push the dryer toward the rear, then remove two larger nuts from top left and top right corners. No nuts at rear, just clips that slide in/out. This allows lid cover to be pulled straight out (I had to remove the overflow tube on front right of tub, and one semi-rusted nut-driven screw from the Hot/Cold filler plate which is at the rear of the lid cover. That will make it easier to manipulate the cover and release the 4-pin plastic connector shown in pictures at the left rear corner. Then the entire cover/lid slides out easily as you may have to push the dryer top back to ease it out. Then flip it over and replace the switch and slide the 4 wire connector back under the plastic trip. and reverse the un-install. 4-pin connector is flat-keyed on one side, but it is tight to get to. My OEM part even included a new fuse (19.95 + shipping) Unit is now working fine for last 2 weeks.
SOURCE: Maytag stackable LSE7806ACE - dryer wont run...washer is fine..
I had the same problem, take the easy rout first and check for obstructions in your venting. Mine was clogged and it shut itself down (to protect itself?)
SOURCE: Kenmore washer overflows during rinse cycle.
SOME OF THESE MACHINES HAVE TWO PRESSURE SWITCHES IN THEM, ONE FOR THE MAIN WASH WATER LEVEL AND ONE FOR THE RINSE WATER LEVEL. CHECK FOR A PLUGGED AIR PRESSURE HOSE FIRST AND THEN CHECK THE PRESSURE SWITCHES.
SOURCE: Washer won't agitate, drain or spin
Hi Xinia_s
The lid switch needs to be replaced. although it seems to be working for the water intake valves it will not work for the motor. it is not the fuse. the main fuse sits right above the motor's start capacitor in the lower left side of the lower cabinet; had it been the fuse it would'nt even fill w/ water. have the lid switch replaced and it should do the trick.
SOURCE: whirlpool thin twin ylte6234dq2 washer/dryer water overflow!
first access the tech sheet and run any diagnostics it shows for the machine and if this passes,then check/change the fill switch on the control panel along with fill tube from the wash tub base if kinked or plugged
