SOURCE: when i go to start the ski doo it doesn't want to
first of all check your fuel filter and then the fuel line,it can be the fuel line inside the tank (if it do it only when in low gas)it can be the fuel pump or the suction line from the motor base i hope it will help
SOURCE: I have a Ski doo 583 RAVE motor theat backfires
It sounds like you have a reed problem they should be in a "cage" just behind the carbs on the cylinder and if they were missing a piece or if they were cracked it would cause the engine to backfire. If they are in good condition they should close against the cage and stop the back pressure coming through the carbs.
