SOURCE: I have a RCA R56wh78 projection power button flashing green.
Thats the classisc sign that the CP150, CP114 and CP120 capacitors need replacement. You can get the repair kit called CP150, CP120 and CP114 at www.tvrepairworld.com which contains the capacitors and the CD with step by step instructions on how to do the repair.
Testimonial: "Thank you. I will try this. I just dont understand why it worked with all of the button pushing on the front of the tv. Is this going to be a hard job"
SOURCE: My R52WH74 projection tv is giving me a code 9 then 5 blinks
Replace the deflection board. You need the ITC222A deflection board PSB-260 available with installation instructions from www.tvrepairworld.com
SOURCE: RCA R52WH74 PROJECTION TV ON
Hello
Just unplug the TV from AC mains wall socket. Wait for about 15 minutes and replug it and see whether it helps you. This process will give a hard reset to its V-Chip features. The replug the TV to AC mains and see whether it helps you. If not the power supply board of your Tv is faulty and should be replaced.
This is the power supply board to your TV. The only relaceable components are its two capacitors. See whether these capacitors have bulged top side. I hereby attaches an other picture, not related to the power supply to yours; just to give you an idea about what a bulged capacitor will be.
Just see the red arrow marked cpacitors. The top side of them are bulged, and is damaged. You can see a good one at the top right part of the picture. If there is any capacitors on your tVs board look like these damaged ones, replace them with same size and capacity. If they are no seemed to have damaged, the switching circuit secion has been damaged, and is irrepairable. The only way is to replace it as card basis. You can buy this board eiter from any electronic spare part shop at your town, or from the Authorised Service Center for RCA at your town.
If you want anymore assistance from me, feel free to get me by Fixya.
