SOURCE: Bernina Activa 135 sewing machine
Hi , the pedal micro switch are stuck , you may visit fixya repair service just , (enter zip area), you can find sewing machine repairman near you
SOURCE: Elna 9000 sews automatically
Most likely this is a problem in the foot control and it will need to be replaced or repaired.
sewman7
SOURCE: The Reverse stitch button
The feed mechanism needs to be oiled. Take off the bottom cover and look for any place where two parts move against each other. Some binds can be very difficult to remove. Try spraying everything with a light weight oil (I like Tri-Flow) and let them soak over night. Then manually try to move the feed dogs with your hand. Hopefully it will break loose.
SOURCE: Elna machanical sewing machine
50 year old elnas made stitches by cams. look to see if the machine has a cam in it. you can see this by opening lid on top of machine. cams are black with red or white showing the pattern of the cam. could also have broken cam stack gear. That would require technician with elna experience
SOURCE: foot pedal not working
yes, it is possible that the foot pedal can go out,, it would be a good
idea to have the foot pedal checked at a repair shop to see for
sure
Testimonial: "I went to sewing machine store today and the pedal checked out as dying, so ordered a new one. Thx again!"
