not car moved this to camera
no model told at all
the batteries are no good or connections rusty on most
many of these are 13 years old and sold as new by liars endless on the web .
models
vcp-nnn (lots )
DMX-nnn (lots)
the endless list is here.
what it uses inside who knows lacking model
the battery is bad, or allowed to leak and damaged connectors.
The yellow RCA connector is the video line - connect this the VIDEO IN on your TV
The white or red RCA is the audio line - connect this to the AUDIO IN on your TV
The black tube like connection is the POWER to the camera - there should be a separate charger adaptor to connect this to.
Formular for Inflation RateInflation= [(T1 - T0)/ T0]* 100Where; T1is the price at the end periodT0is the price at the start period(T1- T0) is the difference between the 2 time periodsT1= N$147,000T0= N$7000Inflation = [(T1 - T0)/ T0]*100= [(147000- 7000)/ 7000]* 100 = (14000/7000)*100 = 2*100 = 200
Yes it could but i would suggest checking the crank position sensor as it will not throw check engine codes. Also go to an auto store and have them pull the codes for you for free.
there is bended rod called as dipole in ur antenna..both ends of dipole should be connected by a coaxial cable. connect it to ur fm recivers antenna. to have much gain cut both ends of directors which are strait pipes (2 to 3 cm)
