30 gallons of water weighs 300 lb and then there is the weight of the aquarium itself and accessories - that is a lot of weight that is likely to distort even a robust cabinet if it isn't standing on a perfectly flat and level floor, the most common reason why cupboards, cabinets and chests of all sorts never seem as good at home as in the shop.
Another possibility if the unit arrived as a flat pack, perhaps the attention to detail during assembly was less than precise...
SOURCE: how do I remove cabinet
I had the same problem but it's the FRONT Panel you need to remove. Before you start, unplug the thing first. BTW I did the whole proceedure in 10 minutes using an electric screwdiver / philips bit and a socket set with an 8mm socket with my leg in a cast. You can do better, I'm confident!
Two 8mm hex head bolts hold each fin on the drum. They can be tightened. You need to open the dryer front since they bolt from the outside of the drum. To open the dryer front you first take the door off by removing the two philips head screws, then slightly lift the door and pull toward you (the door hinges have little hooks on the end that inserts into the slots (this little design keeps the door from falling off during removal and install-nice). Then remove the two philips screws on the other side of the door opening (opposite the door hinges). These screws hold two plastic brackets (be sure to see how they are aligned before you remove them so you know how they go back on.
Now the front frame panel looks like an "H" . Grab the top two arms of the 'H" and give a quick ****. The top arms of the 'H" will come loose. The bottom part is held by a couple of clips, just pull up and the front panel comes off.
You will be able to spin the drum until the hex bolts for the fin(s) in question are visable / reachable from the right side (just above the heater unit-hope you unplugged the dryer earlier). I tightened it using an 8 mm socket. Might as well check the rest while you're in the "position". LOL
Now reverse your steps: put the front panel back on the bottom clips and snap the top "H" arms back in place. Reinstall the plastic clips / screws and then put the door back on.
SOURCE: weber cabinet door won't stay shut
Try moving the catch foward there are two screws on the sides you can losen and move the catch
SOURCE: What colors does Top Fin Aquarium Gravel come in?
Top Fin Aquarium Gravel comes in an assortment of colors
including midnight black, Mardi Gras, Caribbean Sea, classic beach and river
rock. To get a complete list of colors
and to buy these products go the link below.
SOURCE: What is a closed aquarium stand?
A closed aquarium stand is made from pressured wood and can hold really heavy aquariums of 50 gallons and up. Just like the open stand, closed aquarium stands are rectangular
