SOURCE: how to change the battery on my BE365-CAM-716 Schlage Keypad Deadbolt
Problem fixed by having my wife look it up on the Schlage website. The deadbolt has a flash memory so your combinations and codes will not be lost when the batteries are changed.
SOURCE: new schlage deadbolt stuck in locked position
Make sure that the tang from the lock side actually engage the mechanism in other side of the door. If the tang is too short or not engaged the lock will not work. Also check that the two screws connecting the lock to the other side is actually tight.
SOURCE: I would like to program
How can I program my electronic keypad lock when the instructions with the programming code have been lost?The
back plate of the keypad side of the lock on the exterior of the door
has a sticker which includes the serial number, six digit programming
code and two pre-programmed four digit user codes. The lock must be
disassembled to a point the exterior of the lock can be pulled away from
the door and the information on the sticker made note of.
This link will give you instructions for various models of Schlage locks:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
There is a video on that page.
SOURCE: deadbolt behaves like dead battery
Does it do that only with the door closed... or also with it open??? Something is binding the deadbolt and causing it not to be able to open...I have seen doors that you would have to pull them closed as the deadbolt tries to open to take pressure off of the deadbolt so that it could open...
Also make sure that the deadbolt is not binding anywhere...as it goes in and out.
Other then that the motor has simply become too weak to move the deadbolt.
heatman101
