I've tried to unscrew the front plastic fascia but I can't unscrew it with just my fingers and there are no notches for a lens wrench type tool. Anyone got a solution?
SOURCE: Replace front brake pads 2000 Chevrolet Blazer
yes remove one bolts where caliper bolts to the slide assembly older models had allen heads
SOURCE: 87 suzuki samurai change front brake pads
the allen wrench bolts should be the correct bolts to remove brake caliper to allow access to pads.
hint: there will be only two bolts to remove and they will be the same maybe different lengths
SOURCE: What rod or screw or
going by your question i`d say you don`t have the ability to perform this job yourself.to just adjust the front end alignment you don`t need to remove any components.you do need an alignment machine to get the angles set to specs,there are 3 angles that need to be checked,castor camber and toe-in otherwise your tires will wear and the car won`t go down the road straight.
SOURCE: Can't remove right front caliper
Might want to get it all buttoned back up and head to a shop. Maybe even call first. Ask if they can use an impact gun to break it loose for you and hand tighten it so you can get back home. A good mechanic should even have tools that will grip a rounded bolt head.
This is a type of good friendly service I would provide to people (until they abused my kindness and mistook it for weakness).
