The TV flickers and then loses power when an AV source is connected such as HDMI, USB etc. The USB is fine until a video file is played. I have updated the firmware with the latest and the problem still continues. Any suggestions?
SOURCE: won`t play or record
take it back and get a new one. Make sure you scan for a virus i use the free AVG
SOURCE: when sony blu-ray plays, lg 52lg70 tv power turns off and on
Try using a different HDMI cable; one that is not simplay or 1.3.
The HDMI can control functions of the TV.
If you get a cheaper cable it may not do this.
SOURCE: LG HT502 wont recognize hdmi cable. it says hdmi
go into the video setup menu, and select HDMI set up and select "ON" that should do it
SOURCE: Acer AX1700-U3700A with variable Audio on HDMI
Your problem isnt in your PC, it's because you chose the onboard sound to listen to music etc, which is normal. Unfortunately, you need to choose the HDMI Audio output if you want sound on your TV FROM the HDMI cable. Right click the sound icon located to the lower right side of your screen and choose (adjust audio properties). Now go to the audio tab and click the output device window and choose your HDMI audio output, whatever it may be called. Just pick the one that wasn't selected when you opened it and click ok or apply. Now all audio output is controlled by your Video card lol. Crazy aint it?
SOURCE: Hi, my lg bd370 will
I had the problem with this player and disc where the audio worked for the previews but once the film started it got jittery and the sound went in and out. I went to the audio set-up and switched it from 7.1 to 5.1 and the problem was immediately solved. Is this the problem you have? I surfed around and a lot of people have experienced this problem with Toy Story 3 and this particular player.
