SOURCE: Maytag MAV6200AWW does not spin
Be sure to check inside basket very carefully to make sure no loose nails or screws or drill bits etc that were left in a pocket are sticking through a hole in the basket and locking it to tub. This is common. If that is not the problem,one of three things has happened. 1 The thrust bearing that releases the brake has worn out. This is the most common and easiest thing to repair. If you tilt the machine back so you can look under it you will see the pulley that turns the transmission. When the pulley turns one direction it works the agitator, turn it the other direction and you should see it push the brake up that is directly above it. The thrust bearing kit includes the pulley and all bearings and washers to release brake. If you are mechanichal and can follow the directions that come with it, it is a fairly simple repair. 2 The brake lining has come apart and "stacked" itself in the brake housing. Replacing the brake is not hard, but there is about 200lbs of spring force pushing against the brake and housing that must be released slowly. I would recommend you call a technician for this just because I don't want anyone to get hurt trying to follow my directions on this repair. 3 An item of clothing has found its way between the basket and tub and has the basket bound up. This would mean removing agitator and basket. It is not likely this has happened, but I have seen it before.
SOURCE: Maytag Atlantis MAV6200AWW; Washer goes through
Maytag Atlantis washer goes thruout washing cycle,but dosen't simse or spin....
SOURCE: my maytag atlantis mav6200aww stops at the rinse
Sounds like a bad timer, which is built into the switch. Replace the timer.
SOURCE: make loud noise during spin cycle
Washer may be out of balance, Move closes around in washer and restart
SOURCE: Atlantis MAV6000 Top Load Washer: Maytag Top Loading Model MAV6200AWW not spinning w...
Here is a tip that will help you with that...
Washing Machine does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
heatman101
