What is fix for error codes F06 E01? Whirlpool Duet model WFW95HEXW0. Door locks but cycle never starts.
This error message means an electronic communications problem. Press pause/cancel twice to cancel the error and then disconnect the power cord from the outlet, wait few minutes, plug the power cord back in and select a new wash cycle.
If you see the same error again then you need to check the connections located between the drive motor and motor control unit.
SOURCE: Door Lock does not lock
1 o 2 issues either a bad door lock, or the machine control board located under the main top is malfunctioning.
SOURCE: Whirlpool Duet Error code F 32
Plug off the wall. Open up behind, you will see a thin tube coming down from the control panel (pressure switch to be precise) to the waste area below. Disconnect this carefully from the top, blow into it, air should pass thru, it shd not be clogged; refit carefully. Before refitting, fit a similar tube to the pressure switch & blow - you should hear a click; if not there shd be a problem with your pressure switch. Anyway refit your old tube & try the machine.
Dont forget to refit the main exit hose at the position you found it. All you guys are going to rate me....................
SOURCE: error code f22 whirlpool duet wash cycle
f22 is a door lock error try this hit cancel turn your dial to another setting, hit start and once it starts hit cancel again and it should unlock. thats what i did anyway.
If you're getting an F22 error, you will want to check anything to do with the door latch switch.
SOURCE: F06 and F14 error codes
Before you replace the control panel use a tester on the cable to check continuity .. if the cable is faulty you will get this fault
Testimonial: "Thx. All OK. I labeled all 14 cables, installed new one, and...success. It's said CCU relays could be culprit, and can be replaced for $4, not $240."
SOURCE: Error code f06 model 11045089404
"F6" is a Motor Speed error problem. It is commonly attributed to either a broken or slipped drive belt, defective Drive Motor, bad Motor Control Unit (MCU), and/or the interconnecting wiring. The following link explains:
http://www.fixya.com/support/r3608706-f06_error_code
First, remove the back panel of the unit and make sure the drive belt is not broken, or has not slipped off the drum pulley.
Then, remove the top panel of the washer and check all the connector plugs between the Drive Motor, MCU and Central Control Unit (CCU). Check for loose connections and then unplug each connector and plug them back in (one at a time) to ensure they are snug and making good contact. The top panel comes off by removing the three screws that hold it in place in the rear of the washer. With the screws removed, the panel will slide back, then off.
NOTE: You only need to check the connectors that affect the drive motor and MCU circuitry.
The MCU has a tachometer mounted on it. If it is determined to be the cause of the problem, it is considered part of the MCU and cannot be replaced separately. The MCU is not serviceable and will require replacement.
Next, check the motor windings to ensure they are reading the proper resistance. Followed by continuity checks of all the interconnecting wiring between the drive motor, MCU and CCU. You should not need a service manual because each one of these washers comes with a technical data sheet.
For more in depth troubleshooting tips refer to your tech sheet located inside the washer behind the lower toe panel. You will need to locate and remove the screws under the bottom front edge of the toe panel. Once removed, the panel will drop down, then come off. If the tech sheet isn't located directly behind the panel, it will be affixed to one of the interior cabinet walls. The tech sheet includes all error codes, test points, diagnostic procedures and helpful illustrations to assist in troubleshooting and repair of your washer.
Replacement parts (if required) can be purchased at any of the following websites:
searspartrsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions, or require additional assistance, please let me know. I hope you find this information helpful.
