SOURCE: wi fi driver software for compaq pressario c734TU laptop for winXP
for win xp, u gys can use these dirver ...
i am sure these wil work
wifi http://tinyurl.com/687b9n or http://tinyurl.com/yxunwu
sunder singh
sound driver not inn=stall and not work proper
compaq c734tu laptop
SOURCE: about Wi Fi drivers?
The drivers for your computer can be found at http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=LAT_PNT_PM_D610&os=WW1&osl=en&catid=&impid= .
Select "Network", then select the wireless adapter in your system. If you don't know, try them all.
SOURCE: the combination fn+f8(the wi fi button ) is not working
nothing you can do about it ... if you dont use the wireless you can disable-it from bios and the light willl shut down....
i have the same laptop ..and except the battery that goes fast it's a reliable laptop
PS you would better use w7-x86/32 bit and it will performe better
SOURCE: I had recently purchased Samsung
Dear Meghna
you have not mentioned the wifi router make and moel
no problem
for this you have to go to your router web admin to add your device as WPS client
this will solve the problem
for that all the models are differently configured so you have to try playing with the settings yourself, if you jumble up the settings of you wifi router there is a reset switch in all the routers that restors your router to factory settings.
if you find my information useful dont forget to vote me with the thumbsup
thankyou and take care
Gagan Gupta
