Building Materials Logo
D
Dan Vincent Posted on Dec 29, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I test if the safety sensor is working? My door won’t go down and flashes when the button is pressed.
  • Anthony Pettenger Dec 30, 2018
    If the sensers are not blocked, check the alignment. If the sensers were bumped they may have been moved slightly, enough to move the beam and cause a false sensing that there is an object in the way
Justjim
Level 1:
New Friend:
  • Contributor 28 Answers
  • Posted on Jan 03, 2019
Justjim
Contributor
Level 1:
New Friend:
Answers
28
Questions
0
Helped
13028
Points
54
The sensor eye and the reflector need to line up. Sometimes the reflector gets bumped and won't reflect the beam back to the sensor making it think that something is in the way.
Lawrence Oravetz
Level 3:
  • Master 10,558 Answers
  • Posted on Dec 29, 2018
Lawrence Oravetz
Master
Level 3:
Answers
10558
Questions
Helped
2695738
Points
29284
First, look to see if something is blocking the sensor path close to the door. That usually gets the door working. If the safety sensor was not working, there would be no lights indicating power is applied to the sensor.
5 Related Answers
ltfrc
Mike Schmidt
  • 227 Answers
  • Posted on May 25, 2009
SOURCE: New Craftsman 95320 1/2 hp chain drive only opens door ~6"
Try this link
http://www.garagedooropeners.us/helpgifs/chamberlain_troubleshooting.html
protek480
Craig Butler
  • 1730 Answers
  • Posted on Jun 30, 2009
SOURCE: Door goes up, Won't go down.
It sounds like the limits are out of adjustment. With the door down, rotate the down limit until it clicks. Then raise the door manually, and set the up limit until it clicks. You should be able to hear the switch 'click' when it activates. Pay attention to which way the plastic nuts are moving on the screw going up and down. That way you know which way to turn them to set it.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Anonymous
  • 3197 Answers
  • Posted on Sep 15, 2009
SOURCE: Garage door motor reset button must be pressed to work again
It sounds like you have a bad wall control. You can check this out by replacing it with an inexpensive door bell button.
Anonymous
  • 3197 Answers
  • Posted on Mar 22, 2010
SOURCE: Liftmaster 1/2 horse Model HBW0777 acts like the
If the main light flashes 10 times when the door reverses it is a door sensor problem. Look closely at the green lights to make sure one isn't flickering ever so slightly. Tweak them a bit.
Testimonial: "It is working properly now Thank You!"
swolfinor
STEVE WOLFINBARGER
  • 504 Answers
  • Posted on May 28, 2010
SOURCE: garage door will not close
HOLDING DOWN THE WALL BUTTON OVERRIDES THE SAFETY EYES.
WHEN HOLDING IT DOWN MAKES THE DOOR CLOSE PROPERLY THE PROBLEM IS IN THE SAFETY EYES.
ARE BOTH LEDS ON? - CHECK FOR A LOOSE OR BROKEN WIRE.
ARE THE EYES WIRED CORRECTLY?
ARE THEY AIMED AT EACH OTHER?
I have a GDO-7 v1 door opener and it is not working. When I press the button to open the door, it beeps twice but doesn't open the door. The yellow led (door status led) is flashing constantly
If you have a GDO-7 v1 door opener and it is not working as expected, there could be several possible reasons for the issue you're experiencing. Here are a few troubleshooting steps you can follow to diagnose and potentially fix the problem:
  1. Check the power supply: Ensure that the door opener is receiving power. Check if the power cord is securely plugged into a working power outlet. If the power supply is interrupted, the door opener may not function properly.
  2. Inspect the remote control: Check the batteries in your remote control. Weak or depleted batteries can cause communication issues between the remote and the door opener. Replace the batteries with fresh ones and try operating the door opener again.
  3. Verify the safety sensors: The flashing yellow LED (door status LED) indicates an issue with the safety sensors. These sensors are usually located near the bottom of the garage door tracks. Ensure that they are properly aligned and free from any obstructions such as dirt or debris. Clean the sensors and make sure the alignment indicator lights are solid and not blinking. Misaligned or obstructed safety sensors can prevent the door from closing or opening.
  4. Test the wall control panel: Press the button on the wall control panel to open the door. If the door opens successfully using the wall control panel, it could indicate a problem with the remote control. Try reprogramming or resetting the remote control according to the manufacturer's instructions.
  5. Check for any obstructions: Inspect the garage door and its tracks for any obstructions that may be preventing it from opening or closing properly. Remove any debris or objects that could be blocking the door's movement.
  6. Consult the user manual or contact customer support: If the above steps do not resolve the issue, refer to the user manual for additional troubleshooting steps specific to your GDO-7 v1 model. If you're still unable to resolve the problem, it's recommended to contact the manufacturer's customer support for further assistance.
Remember to prioritize your safety during troubleshooting. If you are unsure or uncomfortable with any step, it's best to consult a professional garage door technician for assistance.
1helpful
Garage door opener not working
Sensor must show steady light to close circuit and let opener work. If aligned, then there is a loose or broken wire. Try reaiming first to get steady light. Then check all wires . Another way to test and prove that is the issue is if u hold down the wired button at ur back door and the opener closes, then it is sensor issue. Good luck.
1helpful
It opens but won't close unless I hold down the wall control button.
the photoelectric safety sensors are not working. either they are not lined up or they have a broken/disconnected wire. door goes up without them working, but will not go down without the safety system working unless you press and hold down button.
Kenmore elite sensor smart electric dryer Model 110 65066500 I have power but won't start
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=MhVUEhngZMg
https://www.youtube.com/watch?v=9xD7lCXJ0ZM
https://www.youtube.com/watch?v=sTRP6kHqAFs
Hey GOD IS GOOD !!!! WHICH IS WHY MY ADVICE IS FREE
What to Test When Whirlpool or Kenmore Dryer Won Start or Run Troubleshooting Why Your Dryer Won Start PartSelect com Kenmore Whirlpool Dryer Won Start Easy Fix
3helpful
Green light flashing 4 times,sencors lights on,press & hold wall button to open.others wont work
The green light flashing 4 times is sending the code for " Safety reversing sensorsslightly misaligned (dim or flashing LED)". These are the sensors in the doorway. Tweak them a bit.
1helpful
My door will not go down from remote.It starts,jerks and quit ,lights flash.It is the same from main wall remote also.I have to hold down the the master button for door to go completely down
It is safety "eyes" sensor issue with your system. Lights flashing on the main console indicate a potential problem. Model up, from yours WD962KD, I believe, has a "smart" wall mountable remote that displays a potential problem. In your case, I would check that both safety "eyes" sensors are working (both should have lights on, one amber and one green). Post if you need more help.
3helpful
Liftmaster 1/2 horse Model HBW0777 acts like the safety sensor is stuck (door won't continue down - re-opens when you let go of the wall button. I can close it with the wall button but I need to hold it...
Garage door opener won't close, light on unit flashes
Easy problem - and easy (temp) solution.
The safety pet sensors are blocked or broken
Press the button in the garage and hold it until the door is completely closed.....this over rides the safety sensor at the base of the garage door.
You cannot over ride the sensor with the wireless remote.
Check to be sure that the sensors are pointing at one another.
If they are, check the wires.
If good, the sensors have gone bad. Order replacements.
1helpful
2answers
SEARS/CRAFTSMAN 53628SRT Not Closing properly
sounds like the safety door sensors are at fault,also did you reprogram the remotes by pressing the smart button on the logic board,when the safety sensors are bad the door will reverse to open state.you can pully the rip cord to manualy close the door untill you solve the problem.
Top Building Materials Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Building Material Expert? Answer questions, earn points and help others
