SOURCE: In need a new on/off switch for a Tradesman 10" Table Saw, Model 8030, Serial 000864
any 20 amp toggle switch will work.
SOURCE: 10'' delta table saw manual
you might try Dewaltservicenet.com but you will need the model number and you might have to put the dash in between to get it to list the model. Let me know if you need more assistance and if you do I would also need this information.
SOURCE: looking for a manual for a Rockwell model 10 table saw
Hello. this may be of interest to you http://www.owwm.com/mfgindex/pubdetail.aspx?id=2146
SOURCE: My very old Craftsman 10"
Go to searspartsdirect.com and put in your model number. Look at the motor and wiring section. Look at item 16. The motor overload protector. (probably your reset button) WIth saw unplugged, unwire one sid of this switch and test with an ohm meter. You should read through the switch. If it is open then that's why the saw doesn't work. Many of this type of oveload requires quite a push to reset as you're flexing a klixon disc back to make contact. If is open and you can't reset, it's available there although a bit high priced.
Testimonial: "Thank you so much, I really appreciate this information and advice."
