I spilled grease in my new lg oven and used the easy clean cycle. Absolutely nothing came up. It's supposed to have a special enamel and I don't know if I can use any kind of cleaner. Help!
SOURCE: Cleaning better than self-cleaning
What you have read is correct, the catalytic lining can be damaged by corrosive sprays. It should be safe to use 'Easy Off ' on glass though.
The standard Auto clean cycle is the best method of cleaning that i know of.
SOURCE: Easy off ate all enamel off interior of oven
First off i must say that in your owners manuel it clearly states to not use any cleaning products inside the oven..
Second if the cleaner is now completely cleaned off then when put into the bake cycle it could possibly turn the cleaner into a toxic gas. I would not use the oven i would replace it.
Third having the enamel chip off is not a safety concern. it is merely cosmetic. however refer back to number 2.
SOURCE: what should I use to clean the tough spots in the oven
Use Easy Off only.
Self cleaning leads to malfunctioning parts.
It is a nice feature that does not work well.
SOURCE: My oven has the blue enamel inside and I want to
Sorry to read about your problem, I hope this helps you out.
use regular oven cleaner, if you wish
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
