WE have turned it off and we have unplugged it. Still error code
SOURCE: konica minolta bizhub 350
• The Fusing Roller Sub Thermistor does not
detect the required temperature within 30 sec.
after a warm-up cycle has begun; therefore, the
copier does not complete the warm-up cycle.
• The temperature of the Fusing Rollers does not
reach the required level even after the set period
of time has elapsed during a warm-up cycle.
Check that the H1[ fuser lamp] comes on when the Main Power
Switch is set to ON, and correct or replace as necessary.
Check that the H2 comes on when the Main Power
Check the installation of the TH1 and the TH2, and
correct or clean as necessary.
Check the operation of the TH1.
Remove CN80 (4P), and then check that the resistance
across CN80-2 and -3 on the Thermistor is
infinity.
5
Check the operation of the TH2.
Remove CN81 (4P), and then check that the resistance
across CN81-2 and -3 on the Thermistor is
infinity.
6
Check the continuity of the H1.
Correct or replace as necessary.
7
Check the continuity of the H2.
8 Change PU1 - -
9 Change PWB-A
SOURCE: error code f35-3 on konica minolta 7145 copier
How to reset failure codes (F34, F35, F36). To reset failure codes, perform the following: 1. Enter the 25 mode (turn the machine ON, while pressing the 2 and 5 keys). 2. Select [1. software SW settings]. 3. Using the arrows on the left of the touchscreen scroll to DIP SW 3. 4. Using the middle arrows scroll to BIT 1. 5. On the touchscreen select OFF (0). 6. Power the copier OFF/ON.
SOURCE: IError Code C13FO on konica minolta Di1610
C13F0 - Laser error
The laser output exceeds the upper limit value.
The laser output remains lower than the lower limit value.
SOURCE: Error code C-0211 Konica Minolta Bizhub C-351
I have a Konica bizhub c351 with and error code of c0211. I took the back off and played with the black motor that lifts the tray. The tray moves freely and the motor seems to move freely. When I turn the machine on it does not go through any kind of check like it did before it just goes to the same screen. Is there a way to reset this to get it going again to test if there is still a problem
SOURCE: Konica Minolta Di2510 error code C0500,can not
check the fusing unit parts heaterlamp,thermistor & thermoswitch i'm sure one of them is the cause of error c0500
