Sport & Outdoor - Others Logo
Anne Opperman Posted on Dec 26, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am looking for an instruction sheet on erecting a campmaster caravanner I tent please
Matthew Minton
Level 2:
New Friend:
  • Expert 58 Answers
  • Posted on Dec 26, 2018
Matthew Minton
Expert
Level 2:
New Friend:
Answers
58
Questions
Helped
32114
Points
160
Youtube they should have something on there that will help ya
1helpful
2answers
Anyone know where I can get an instruction manual as i have no idea how to erect the two side tents
Hi Debbie:
If you Google the make and model of the tent with the words "assembly instructions" or "picture" you should get all the info that you need.
Example..... Google "coleman tents" and you will get this link
https://www.google.ca/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=coleman+tents
It will give you lots of options to look at.
2answers
Instructions on erecting an andre jamet 1967 super paiotte 1967 tent
Wow! That is not a new model. :-) All I can suggest is that you look for YouTube videos of setting up tents, or lay it out with a couple of friends who have a lot of experience with different tents and give it a try.
3helpful
No instructions giving to erect our tent 6 man regatta hyperdome model no 927/5887
I bought one of these yeaterday. The instructions - for what they are worth are sewn inside the carry bag. So I decided to put it up today. Not as easy as i would have thought, but then this is my first tent of this size. ( saw a nice Outwell Montana 4 in Millets for 225.00 which would have been my tent of choice). But at half price in Argos I couldn't argue that one.
So to put it up.....
lay out the fly sheet in the approximate final position. put poles in as per instructions ..blue to back red to middle and blue to front.. across the tent. ( the pole guides are all colour coded.) Make sure poles are in pins at the base of fly sheet (bending gently to attach). these are attached by the black elastic straps.put in porch pole, put in front to back poles left and right.
Anchor back of tent temporarily with pegs. Lift from porch forward to lift tent. Temporarily peg base of poles, straighten out so that the straps inside tent are approximately perpendicular to each other. Move poles to tension flysheet and tighten anchor points on flysheet using straps buckles to pull flysheet down as far as possible ( to help prevent draughts)., anchor guy lines when happy with final position.
Put up inside ground sheet and attach to points on inside of flysheet. put up rooms starting with the rear yellow hook and work around to front red hook.
These instructions were not specifically provided but this was our first try and probably could be improved on. It requires 2 people for speed if nothing else.
Enjoy
4answers
I have a Coleman Savannah 6 tent but no instructions. Does anyone have any instructions on how to erect this tent?
It does not come with instructions oddly.
However, start with the external frames and then hang the main inner tent onto it. Finaly drag the flysheet over at the end.
The middle legs sort of cross over towards each other and meet in the middle at the bottom - this is crucial!
Hope this helps.
Paul
5helpful
2answers
No Instructions
Peg out the "brown" ground sheet of the inner tent and hold it up like a standard ridge tent.
Put the two shorter upright poles on the inside of the compartment (with something under the feet to prevent damage to the ground sheet). Put the 40mm tubes on the spike that pokes through, and then put the ridge pole on the outside.
Everything should then hold in place while you put the fly sheet over the top with the 2 longer poles at the front.......
tip - line up the seam on the fly sheet with the front of the inner tent as you peg it out....
Good luck
Top Sport & Outdoor - Others Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
