Computers & Internet Logo
Posted on Dec 26, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have an ex-Etisalat D-Link DIR-850L dual speed router and I want to install original D-Link firmware.
Need right firmware and instructions (such as do I start with a certain version and do updates, or just use a later version?
Matthew Minton
Level 2:
New Friend:
  • Expert 58 Answers
  • Posted on Dec 26, 2018
Matthew Minton
Expert
Level 2:
New Friend:
Answers
58
Questions
Helped
32146
Points
160
Should be able to hook it up to your computer with hard wire and put it in if you don't hook it up that way it won't work
5 Related Answers
Anonymous
  • 32281 Answers
  • Posted on Oct 21, 2009
SOURCE: How can i put a password to my N router (DIR 615)?
Connect a LAN cable to the router and computer. Open your WEB Internet Explorer and your in the router's URL IP configuration address.
This will be 192.168.0.1 and the default Login = admin and the default password = (blank) just press Enter.
You can now change the default password.
Anonymous
  • 6 Answers
  • Posted on Sep 22, 2009
SOURCE: D-Link DIR-615 router
default username and password on the router should be
username: admin
password: *left blank*
kakee
Michael Galve
  • 1269 Answers
  • Posted on Apr 15, 2009
SOURCE: DIR-615 D-Link Router Problems...!
Try to reset the router first by pressing the reset button at the back of the router for 20 seconds then power cycle it by unplugging the power for 30 seconds then plug it back in. Here's how to set it up
1. You don't need to use the setup CD that came with it.
2. Make sure you have the proper physical connection
3. From your modem, connect the ethernet to the Internet/WAN port of the Dlink, then your computer to port # 1.
4. Do a power cycle. Unplug power to router and modem. Wait for 30 seconds. Power on the modem first, wait for all the lights to steady then power on the router. You should be all set
Anonymous
  • Posted on Aug 27, 2008
SOURCE: DIR 625 IPSec cisco vpn solution
go to "advanced", firewall settings, in ALG configuration uncheck "VPN". It will work and that's the easiest way to fix this issue.
1alexh
Alex Howard
  • 484 Answers
  • Posted on Dec 30, 2009
SOURCE: Lost Installation CD Rom for D-Link DIR-615
Try going to the d-link.com web site, and see if you can download it from there.
Testimonial: "Thank you for all your help, HAPPY NEW YEAR!"
How do i update the firmware on my Dlink DIR-300 and also where can i find the latest firmware for the same..!!!
DLink.com, go there. Support, device name, read instructions, download firmware, flash device.
I have Dlink DIR-615 Hardware Version: C2 Firmware Version: 3.01 and want to upgrade firmware as it hangs when i use my Samsung Tab2 over wifi...
The new firmware is available with instructions at Dlink's Website.
http://www.dlink.com/us/en/support/product/dir-615-wireless-n-300-router
This is the english address for the support on your model of router.
Dlink dir 600 firmware corrupted
Usually you can login on your browser to you router and go to the management section to check for firmware updates and select that button and it will download and install the firmware. On some models, you have to go to the D-link web site and look for firmware updates for your router. Always check what you current firmware you have installed and check the version of you router modem (A, B, C etc). Then you can manually download the firmware (usually in a ZIP file), open the zip file, and then using your browser connected to the router look for Update Firmware. You will have to go to where (folder) you saved the downloaded update and select that file. It is recommended that you update using a LAN connection and not a wireless connection.
1helpful
ASKING FOR FIRMWARE WHEN AM LONG IN
Seems like the Firmware of the router is corrupt and it needs to be updated.
You can download the DIR-600 Firmware (from D-Link Official Site, under Support Resources). Download the Firmware, read the instructions carefully and proceed. DO NOT TRY TO UPDATE THE FIRMWARE OVER WIRELESS CONNECTION. Do it over a wired connection.
The following video describes the procedure of updating firmware on DIR-600
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
How do i open the NAT for playing my xbox 360?
Download new firmware. Here's the link. Worked for me. http://www.downloadatoz.com/driver/item_dlink-dir-628-dual-band-router-firmware-1-20b08-beta.html
I just bought this router and am trying to get it connect with a Verison wirelss USB mobile broadband. How can I connect it to my computer and an Xbox 360?
For Verizon i found that Currently, the DIR-412 Mobile Broadband Wireless Router is the only D-Link router that is 3G compatible. The DIR-412 supports 3G USB adapters complying with HSUPA/HSDPA/EV-DO/TD-SCDMA networks and works with most major cellular carriers (AT&T, Sprint, Verizon, Rogers, Telus, Bell, etc).
D-Link routers empower gamers to easily connect their Microsoft Xbox to network and experience lag-free online gaming. All you need is a D-Link router to go along with your broadband connection and Xbox Live subscription and you can go head to head with friends and adversaries from around the world.
The D-Link DI-624 Wireless Broadband Router, DI-614+ Wireless Broadband Router, and the D-Link DI-604 Broadband Router have all passed the tests for compatibility with Microsoft Xbox Live with specific firmware. Just download the specific compatible firmware listed below to your D-Link router before connecting to Xbox Live.
  • Click here to upgrade your firmware.
  • Click here for Xbox Live setup instructions with a router.
  • For Xbox Live support, please visit www.xbox.com.
  • If you need more help come back.
    Post / thumbs / testimonial are welcome!
    D-Link DIR 615 Wireless Router problem - Speed goes down freq.
    Please contact the D-link to upgrade the firmware and always turn the router off when it is not in use because it takes the static charges.
    6answers
    D-link DIR-635 router
    Hi, I am assuming that you can connect to your router's web based interface (192.168.0.1). On a PC LAN wired to the router, open a browser; Type "192.168.0.1"; Log-in username/admin and password/(blank); Go to Tools > Misc and the option to select the WAN speed (bottom); Lock the speed down on the WAN port of your router to 10Mbps (Some versions do not have this feature). Hope this works for you. If not pls post back with your modem brand/model. You may also want to log the IP settings (IP Add, Subnet Mask, Default Gateway, DNS Servers) of the PC that is directly connected to the modem when you can access the Internet when not using the router. Good luck and kind regards.
    Top D-Link Computers & Internet Experts
    ExpressFiX
    ExpressFiX
    k24674
    Grand Canyon Tech
    Grand Canyon Tech
    Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
