SOURCE: rear brake cylinders are stuck, can not push them in
I have a 2004 SAAB 93 and just finished replacing the brake pads and rotors yesterday. On the piston itself you should have two little notches. You can either or a GM rotor reset tool that will push into the two little notches and push against the piston while rotating it clock wise. Or the way that I did it was to take a C clamp and put the caliper back on the car. Clamp it on the back of the caliper to the front of the caliper so it will remain stationary. Then take a pair of needle nose pliers and rotate the two notches clockwise while pushing into the caliper. It will take some strength but you should be able to push them in. Be sure that you spray the boot around the piston when some WD 40 so it does not crack and or break during the process. If you have any additional questions about this feel free to email me.
James
[email protected]
SOURCE: CHANGING REAR BRAKE PADS
the best thing you can do is go to an autoparts store and purchase a haynes repair manual for your car. cost about $18, but will show you everything you need to know, with pictures.
SOURCE: How to change my rear brake light bulb
Okay you need to lift your trunk remove any carpeting remove hidden screws to undo light fixture be careful not to drop the case once case is in your hand remove the appropriate bulb that needs replacing after wards reinstall light housing/casing and screws good luck with this. Please Rate Me. And for further assistance you can always ask me.
SOURCE: How To Change Rear Brake Pads on Audi A6 2006
Remove the tires, Remove the calaper bolts, (small heads on them 12mm or so) Remove calaper, Pads are setting in a holder. Lube new pads with litheum grease and place in holder. (look at old pads, one or both may have small metel tab on one end) If the new pads have the tab, put that pad where the old pad with the tab was. (ie. tab to the inside) Press pistion in with a 'C' clamp. If it won't go in easly, it may screw in. If the parking brake cable is hooked to the calaper, it probly screws in. Use large pliers to screw in calaper piston. Place calaper over pads and install bolts (lube bolts) Rember to pump brakes befor driving . to get a solid peddle.
SOURCE: how to change rear brake shoe pads of 2005 mitsubishi lancer
Hello, this do it yourself project is very manageable if it is brake pads that you are replacing on your car; if they are disc shoes it may be a little bit harder. In essence a brake job can be done straight out of a auto manual for your car and is not to diffucult as long as you follow good safety procedures while jacking up your vehicle and removing your wheels. First, I would park your car and setting your parking break will make your rear brakes impossible to get off so do not set it. I would however keep this in mind and be very careful working on your car then. I would chaulk your front wheel with a chaulk block or a brick. I would loosen your lug nuts just to break the intial torque I would then jack up the rear of your vehicle and set jack stands under your car in the proper locations. Then systematically, remover your wheel and then the two bolts holding your caliper to the spindle. Carefully, remove the caliper and do not let it hang becuase you will bend your brake line. Remove old shoes, then compress the caliper with a caliper compression tool from your local auto parts store or a c-clamp and a small block of wood. Inspect the rotor for deep gouges, a blue tint, or if you know you have gotten them really hot before I would replace the rotor. Next, install the new brake pads, put rotor back onto spindle and insert bolts back into caliper housing. Repeat for the next side and put the wheel back on and remember to torque your lug nuts to the proper specification. I hope this fixes your problem for you!
