There are many places for the water to leak out the bottom on those. You are going to need to remove the covers and have a look. Is the water clean or is it part of your brew? In order of most likely to least likely
1) Barista seal at bottom of brew chamber
2) Distributor
3) Tank seal
4) Tamping piston seals
5) Flexible hose or connection
6) Hydraulic Ram
7) Relief valve on end of pump
You are not going to figure it out with the covers on and you will have great difficulty running it with covers off to be certain where it is coming from but that is what most of those issues is going to require.
I have a Krups XP7240 that came with the same error code (0d). I believe that the XP7240 and the XP7245 is pretty much identical inside. The sollution for me was that the connector to the front was loose. After pressing down on the connector, the machine worked perfectly again.
it is a common issue. See the posts for xp7240. The seal within the plunger is worn or dirty or the valve is sticky. Posted both instructions on other posts.
My XP7240 has the same problem. I went through all cleaning cycles and the filter in the boiler still gets clogged up with coffee oils. This causes back pressure and blows the boiler seal out. Easy replacement if you can turn a screw driver. Part number for Seal: MS-5015004. You might as well change the Jack too. (the part that slides into the boiler that compresses the ground coffee. (this is a redesigned double seal unit) Part Number MS-0697072. Both these parts you can get at http://www.krups.com/Tools/Contact/Contact.htm choose your country and email the parts list. Mine cost in Australia $27.00 including shipping. Good luck.
You can just removed the water tank filter (the cylinder inside the water tank) and washed it up. (Actually the filter should probably be replaced). Fix it back in the water tank and tide it safety upon the exit ring.
Don't forget to unplug the machine BEFORE doing this. Next, restart the machine and let it perform the automatic self testing.
Yes, you're machine is identical to the xp7240. Look up the post on leaking xp7240 and follow the instructions on how to open the machine and fix the valve.
You need to open the machine which is easy see my other post on leaking krups xp7240. The grinder can be taken out by removing two torix screws. Probably the electical brushes are gone. Take the grinder engine to a repair shop where they replace them.
