SOURCE: Noise at end of spin cycle
Sounds like the drive block is defective. The drive bloce is a aluminum part that attaches the drun to the gearcase. If you remove the agitator you will see a large nut on top of the basket. If the drive block is worn yo will see aluminum peices on top. It is very simle to relace. You will need a spanner wrench to remove the nut. With the nut removed lift the spin basket up and out. Remove the block. You will see that the new block will only fit on one way. Tap it down untill it will not go any further, replace the basket, make sure you tighten the nut securly replace the agitator and you will be back washing.
SOURCE: Washer agitates, but makes horrible grinding noise. Spins okay.
thanks for posting problem solve :0)
SOURCE: drum makes loud noise when spinning
HI thanks for the question. Frigidaire has a life time warranty. on that part .call them. thanks the appliance doc. please rate my answer. thanks.
SOURCE: noise/not draining on spin cycle
I had that problem and it was the drain pump trying to drain but it coulsn't because it had lint, plastic, 3 underwires a looney some costume jewellery stuck in the pump. By the pump underneath you'll see a black plastic boot leading away from the pump. disconnect this and inside you'll find the lint trap and if you dig you'll probably find the culprit that stopping your pump from moving. Put it all back together and Voila!
SOURCE: Zanussi ZJD1219 Washer/Dryer - noisy spin and dirty spots
Sounds like the main drum bearings have failed, and the marks on clothes are probably grease spots from the main bearings.
It is quite an involved repair, and not one that I would recommend you tackle yourself unless you are competent to do so,as it really is involved.
Please rate my solution.
Thanks.
