i don't know. my generic unit will do similar if i don't have the units moisture level set at a lower number. consider
using your lowest setting as a test.
Hi, It could be a bad compressor, circuit board, or maybe even a sensor or dehumidistat... Here is a tip about dehumidifiers that run but do not extract water from the air..
That part you identified is the compressor of the dehumidifier. Compressor is probably bad or going bad. When compressor go bad the valves start making noise and they lose alot of there efficiency.
attempt to feel the metal fins on the back of the unit. If they do not feel cool, then unit is either out of freon or compressor has failed or compressor is not running. If fins are cool, then insufficient air flow through unit -check fan- or room has very low humidity and humidistat is defective; not shutting down compressor.
