"LF" on display (Long Fill - no water or insufficient water supply)
Press POWER/CANCEL to cancel the cycle. Unplug washer or disconnect power.
Plug in washer or reconnect power. Re-select cycle and press START/PAUSE.
"F9E1" on display (Drain Problem)
"SD" on display (Suds Routine)
When excessive suds are detected, a suds routine automatically starts. This routine removes extra suds and assures proper rinsing of your garments. "SD" is displayed during rinsing and at the end of the cycle to inform you that the Suds Routine was activated. Use only HE (High Efficiency) detergents.
"F--E--" Variables (Washer Problem)
Press POWER/CANCEL to cancel the cycle. Select RINSE, DRAIN & SPIN if there is excessive water in the washer. Re-select cycle and press START/PAUSE.
SOURCE: My maytag commercial 2000 series
Verify if the shipping bolts were removed. The machine will be shaking and moving if they weren't. In the back of the machine there should 4 big bolts attached with nuts.
SOURCE: Maytag series 2000 front load washer poers on but will not run
I am not familiar with this model, but if it has a filter, clean it out. Unplug machine first, and place a catch pan under filter if possible. Have a mop and bucket handy.
SOURCE: What does error code LF on my Maytag 2000 series front load washer mean?
Maytag Customer Phone Number Shortest Wait Best Support
Phone Number
800-688-9900 or 800-344-1274
Say "Customer Service", say the type of appliance you are calling about, then "yes, or no" then "service help", then "no" finally give the phone number your unit is registered with.
24 mins - approximate wait time ' Operates Mon-Fri: 9:00am - 7:00pm EST
SOURCE: what does F7E1 mean on a maytag 2000 series washer
water flow error. Clear out trap under front panel. This will allow washer to run. Also drain will improve
