SOURCE: best way to drain washer to check pump or hoses
broken lid switch usely the call what kind top loader is it
SOURCE: Error code F-28
It may be that the drain pump is not the problem at all. Error Code F-28 on the Kenmore HE2 means that there is a signal error between the Central Control Unit (CCU) and the Motor Control Unit (MCU)
SOURCE: Check Pump on front loader kenmore HE3 elite
Remove the lower front panel 3 screws across the bottom. Pump will be behind this panel.
SOURCE: frigidaire frontend washer LTF2140ES3 will drain not spin
There is an auxiliary switch in the door lock and switch assembly that is activated at the end of the wash cycle to advance to the spin cycle. When the machine works except advancing to the spin cycle, it signifies that this auxiliary switch cannot be activated and the door lock and switch assembly is faulty. Replaced the door lock and switch assembly (part #131763202) to fix the washer.
Disconnect power to the machine. Open the washer door then look for the retaining hoop securing the door seal around the lip of the door opening. Stretch the retainer spring of the door seal retaining hoop then remove it.
Carefully peel off part of the door seal from the lip of the door opening near the door lock and switch assembly. Remove enough of the door seal to gain access to the door lock and switch assembly.
Remove the screws securing the door lock and switch assembly to the front panel. Once the screws are removed, lift the door lock and switch assembly then pull it away from the front panel.
Take the door lock and switch assembly out of the machine. Disconnect the wires from its terminals then connect it to the new door lock and switch assembly.
Put the new door lock and switch assembly back into position in the front panel and secure it with the securing screws.
Properly put the eased part of the door seal back over the lip of the door opening then secure it with the retaining hoop.
SOURCE: I have a whirlpool WFW9600TW01 front load washer.
Hi dear.I may have solution for the SUD error.You can give it a go.But I do not know any thing about F35 one
The motor control unit senses a suds lock condition by analyzing the current draw on the drive motor. If “Sud” is displayed a potential suds lock is detected. This may signify a bad pump, an extra heavy load, excessive detergent, or excessive suds.
Potential Causes
• If too much detergent was used, run the unit through a Rinse/ Spin cycle then a Normal cycle without adding any detergent. This should clear the unit of the excess detergent.
• Check the drain hose and make sure it is not plugged or kinked
• Check Wire Harness connections to the Drain Pump, Pressure Switch, and Central Control Unit (CCU)
• Check / Clean Drain Pump Filter of foreign objects
• Check Drain Pump
• Check the Pressure Switch
• Check CCU
Replace failed component.
As it says run couple of rine cycles it should get back to normal.I hope that helps you.Thanks.
Hello & Welcome to FixYa
ND error in your Front Load washer
indicates no drain issue. To start with check the drain hose for any clogs and
try cleaning it, then check restriction in drain pump assembly or loose wire at
the pump, located inside the bottom front access panel of the unit. Please get back to me if you have any other questions.
Kevin
F02 is a drain error in your washer, if
the unit is unable to drain then after 4 minutes it will display suds and then
F02. The first thing that should be done is cleaning the drain hose and the
drain pump filter, you can take out three torx screws from the bottom front
panel and then clean the area completely, lift up the cap to clean the filter.
If the error returns then check the drain pump if it is not working then
replacing the pump is recommended repair. Please get back to me if you have any
other questions.
Kevin
F2 is a drain error in your washer, if
F2. The first thing that should be done is cleaning the drain hose and the
other questions.
Kevin
Here is a tip that I wrote about the LG OE Code and the causes and fixes...
Here also is the complete list of LG Codes
heatman101
