lila, yes you have to put the battery on the charger to charge the battery, if not the charger wont charge anything, after you put the battery on the charger hold, before that don't forget to equalize the pin charge with the battery there was a marking or emboss note negative pole and positive pole for the battery fit on it charge, then you can go for the electric plug. For additional note there is light indicator green for full battery, orange for the half battery energy and the last one is red light blink for the on going charge the battery. i hope it help, remember safety first.
Sounds indeed like the battery is dead. You could try checking it with a volt meter. If the volt meter says it is fully charged then you have a problem with the camera instead
Steps : Check the type of batteries you are using. Many a times , less powerful batteries gives issues.When u r charging External charger with battery - will give you blinking light .. which is the indicator for charging.. Check the manuals of the charger to see the meaning .. I feel that you need a replacement battery Or charger needs a repair.. Your question is not very clear though.!
Disconnect the camera, remove the battery and after a few moments reinsert the battery. Then switch on again.
When you charge the battery in the camera, the camera could think it is connected to a PC, because the USB cable is inserted. It could be you are using a USB cable, that not came with the camera. If the error keeps coming back buy an external (Universal) charger, to charge your battery. Modern universal charges can charge almost every camera battery on the market. In the long run, it is better for the camera and for the battery, when you charge in an external charger.
Keep the contacts clean with a dry cloth.
REASONS OF SAMSUNG GALAXY S4 NOT CHARGING- GREY BATTERY PROBLEM
The main reason of Samsung Galaxy S4 not charging- grey battery problem is a shorted charging port. There may be several reasons for it such as sometimes dust entered into the charging port and causes this problem. Sometimes the bar across the center of the charging port gets bent.
SOLUTIONS TO FIX SAMSUNG GALAXY S4 NOT CHARGING- GREY BATTERY PROBLEM
Method 1 If your Galaxy S4 falls and you start to face Samsung Galaxy S4 not charging- grey battery problem, then take a pointed wooden toothpick, a magnifying glass and a strong light and see carefully if any bar across the center of the charging port is in the center and not bent to touch one of the sides of the shell. If you find that it is bent then straight it using the toothpick point carefully.
Method 2 Look for the dirt into the charging port that it may pick up from anywhere. Take a thin needle and gently insert it in the charging port to take out the large piece of dirt from it. But you have to be very careful so that you do not make any damages of the charging port. You can do this by using a can of compressed air or dust/hair blower that will blow out the small dust particles from your phone's charging port.
Method 3 Some users reported that they have found solution of the Samsung Galaxy S4 not charging- grey battery problem by taking out the battery from the phone , insert it into another Samsung Galaxy S4 ,and then again put it in back.
So follow these steps to get rid of Samsung Galaxy S4 not charging- grey battery issue.
No i think it is the problem of over charging . You need to note the exact time of charging of your camera and never charge beyond that time. Because it will get dead soon.Beware!
