Toys Logo
Anonymous Posted on Dec 20, 2018
Long 460 tractor. Rear hydrauliclift does not work.
Kardoc
Level 3:
Top Expert:
  • Master 7,503 Answers
  • Posted on Dec 20, 2018
Kardoc
Master
Level 3:
Top Expert:
Answers
7503
Questions
0
Helped
2760369
Points
58323
Https://tractorpoint.com/forum/long-tractor-review/194898/1/Long-460-hydraulic-question.html
This is a thread that talks about hydraulic problems on a Long 460 tractor
Ih 574 firing order
firing order of 1342, rotor turns clockwise when viewed from the rear
460 diesel farmall - having issues starting and have recently replaced glow plugs and still having issues starting tractor
look at the instructions again and if it still doesn't work bring it back and explain to the person what happened
Where do you check hydraulic fluids on a 460 international tractor
I own one. Most have a plug in the top of the trans/hydro case to the left and rear of the gear shift leaver. It takes a 3/4" drive to open it. I use an extention and brake bar or ratchet. The fluid should just all most reach the opening. the books state it should hold 8 to 10 gal. I have found my 460 Utility holds almost 20 gals.
I have an international 460 tractor and i ma trying to find the serial number. All I have found for a number is 10865, but that doesnt fit into and of the serial number references that I have found. Does...
I have a International mid sixties 460 tractor. Have drained fuel, changed fuel line and filter. Carb has been taken off cleaned no issues. Will start and run for a few minutes sometimes longer than others. Seems like there may be an issue with the governer. Any ideas what to try next. Thanks
Where do you add hydro fluid in a 560 and does it run the power steering also
ther will be acover on rear deck plate next to shifter this is the fill hole check plug will be onleft side of rear end housing under clutch rod [pipe plug] fill until fluid drips out check plug
2answers
Farmall 560 hydrolics wont work on the bucket
i am not sure but check the levers and the inside of the lever control movements.
We have an IH 460 Farmall. It ahs been running
check the carb out clean it and the lines also just to be sure check the sparkplugs
13helpful
3answers
What kind of hydraulic fluid can i use in my farmall 460 that is affordable
universal hydraulic fluid is all we use it is used for the transmission and the hydraulics, about 25 bucks for 2.5 gallons, put in at the gear shift until it comes out plug below cluch pedal. Check any cenex gas station .
Top Toys Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Toy Expert? Answer questions, earn points and help others
