SOURCE: konica minolta bizhub c353 replaced fusion unit,
You did not mention the specific code. But if it is a fuser warm up failure code such as C3421 or similar you must use the proper reset procedure for the code.
Here is the procedure. If it does not work for you then reply with the code/indication you have and I will address it.
1. Turn OFF the main power switch.
2. Turn main power switch on WHILE pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
SOURCE: i have konica minolta bizhub c353 i have problem
Most likely it is your magenta cartridge or magenta developer unit.
did you recently change cartridge?
Are you using original cartridge?
SOURCE: i wanna know how to reset the maintenance time konica minolta bizhub 750
bizhub c252 how do you reset enter serial number
SOURCE: Konica Minolta Konica Bizhub C353 the screen is not displaying screen
check cable between LCD and machine, possible unplug!
