Washing Machines Logo
Alan Whitfield Posted on Dec 18, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Bosch wcm5 ipx4 washing machine smokes when its on spin how do i fix please
Check belt under unit loose or broken
keith jones
Level 3:
Master:
  • Bosch Master 747 Answers
  • Posted on Dec 22, 2018
keith jones
Bosch Master
Level 3:
Master:
Answers
747
Questions
Helped
314546
Points
1478
Check how hot the motor gets after a spin cycle its sounds like a faulty motor
5 Related Answers
barkencoa
Barry Coates
  • 3463 Answers
  • Posted on May 30, 2009
SOURCE: Not Draining or Spinning
Check to see if there is a removable lower plastic cover at bottom front of washer, if there is remove it ,and on the lower right hand side, you should find the pump filter.
Unscrew anti-clockwise, remove and clean.
Please rate my solution.
Thanks.
Anonymous
  • Posted on Jun 12, 2009
SOURCE: bosch wae24363 washing machine, coming up with f17 error code please help
I had this same message last week. It is to do with the water intake (i.e. the water coming in to the back of the machine). If you have checked that the hose isn't trapped or kinked, unscrewed it and checked the filters at each end for blockages (rinse out if necessary), and you still get the F17 message, it may be because your water pressure is too low, in which case you need to contact your landlord (if you rent) or thames water if the problem is external (especially if there are any works going on near your house). Hope this helps!
barkencoa
Barry Coates
  • 3463 Answers
  • Posted on Dec 09, 2009
SOURCE: my Bosch classic 1200 express washing machine wont drain or spin
Possibly a blocked filter or pump.
Ths filter should be at the bottom right front of washer, sometimes behind a removeable cover at the bottom of washer.
To clean it, unscrew anti-clockwise, remove and clean.
Anonymous
  • Posted on Jan 07, 2010
SOURCE: bosch washing machine flashing red lights
all lights are flashing on bosch classixx express no thinh working no water intake door is locked what is the problem and can i do it myself
prem mathew
  • 662 Answers
  • Posted on Jun 15, 2010
SOURCE: mACHINE STICKS WHEN SPIN PROGRAMME REACHED
The 03 error code is the drain. Disconnect the drain hoses and check for blockages. If no blockage "time" the drain interval. If it's more than 6 minutes it's the pump. Also make sure you're using the correct type of soap so the ball check valve on the bottom of the outer drum isn't getting fouled with excessive suds. Also disconnect the drain hose from your house plumbing and let it free flow on it's own. This will tell you if the block is in your plumbing, and not in the machine. Assuming that your filter is clean.
Pl rate me ‘very helpful’ for the free help!
1helpful
Speed Queen LTS90AWN will not go into spin cycle I replaced the door switch and door lock switches.
Drive Belt
Inspect the drive belt to determine if it is broken or if it is loose on the pulleys. If the drive belt is broken or loose, replace it.
My machine is not washing it can spin but not wash
If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. ... 1 Check the washing machine's spin cycle. If this works, the motor is operating and the belt is not broken. If the spin cycle doesn't work, the belt may be loose or broken.
https://www.hometips.com/repair-fix/washing-machine-agitate-spin.html
https://www.youtube.com/watch?v=LMgRO4GAgBg
My Bosch washing machine won't turn the bowl
Hi Justene,
i Think its control circuit has a problem.
or the fuse for motor drive circuit is damaged.
please check with electrician.
regards.
nuwan
Hi, i have a bosch classixx5 washing machine(1400) , it's going through it's cycles until it tries to drain & then nothing, it won't drain... Please could you offer suggestions & s
You first of all need to check the pump filter. This is located at the bottom front right of washer. Look for a drop down flap or cover, once located, unscrew filter anti-clockwise to remove and clean. Of course be prepared for a lot of water and junk. The pump itself is directly behind the filter housing, check there to see if anything is stuck in the plastic blades. It should turn freely. Your washer door will not open if there is water in the washer, just some kind of precaution, so don't force the door.
Pl click if helped..
How do I access the filter/pump on a bosch ipx4 integrated washing machine?
How do I access the filter/pump on a bosch ipx4 This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
http://www.youtube.com/watch?v=2p4G9ibMAMI
2helpful
Washer quit? After start button is pressed, door locks water starts but no spin, I can hear a relay clicking, every 30 seconds or so but the drum won't turn. Is there some sort of reset on this thing? Its...
Hi, I would first check to make sure the belt hasn't simply spun off or broke before jumping right to it being "smoked". That is what it sounds like, based on your description. Pull the back panel off and visually inspect the components, look for a losse/broken belt, loose wiring harness. I'd suspect the belt is off or broken since if the motor where bad that should initiate an error code. Lef me know what you find and I'll try to assist you further...if need be. Good luck. Please take a moment and rate this info accordingly to its helpfullness to you. Macmarkus :)
1helpful
Bosch Washing Machine drum won't spin
It doesn't spin If your washer won't spin, check these: It doesn't pump or spin It pumps, but doesn't spin It spins only with the lid closed It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows: If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt. If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these: The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it. A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.) The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician. The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor. The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it. The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle.
2helpful
Washer doesn't spin ; model 3200 bosch; 4 yrs. old; other cycles work
Although all brands are different in design, the basic concept is the same. When a machine won't spin, there are several things to consider:
  • Is the belt broken? Loose?
  • Does the lid switch click when closing? (see video below)
  • Does the spin solenoid engage? (1984 and before)
  • Drive coupling worn out? (on some newer Whirlpool & Kenmore top loaders)
  • Clutch worn out?
  • Current to motor? (Use voltmeter to check)
Crunching sound at the commencement of spin cycle
hi
The drive belt (or belts) of a washing machine may become worn or damaged, causing noisy operation or stopping the washer entirely. A damaged drive belt is easy to replace. Remove the back panel of the washer to gain access to the belt. To remove the belt:
Step 1: Loosen the bolt on the motor bracket and move the motor to put slack in the belt.
Step 2: Remove the old belt and stretch a new one into place on the pulleys.
Step 3: To put tension on the new belt, use a hammer handle or a short pry bar to push the motor into position while you tighten the bolt in the adjustable bracket. The belt should have about 1/2 inch deflection when you press on it at the center point, midway between the pulleys. If the belt is too loose, it will slip on the pulleys, causing the machine to malfunction. If the belt is too tight, it will wear very quickly and will probably become so hot that it will start to smoke or smell.
Loose pulleys can also cause problems. Most pulleys are fastened to shafts with setscrews around the hub of the pulley. These screws must be tight or else the pulley or belt will slip. The resulting malfunction may seem to be caused by a faulty motor, but it can be corrected by tightening the pulleys and adjusting the belt. For this reason, always check the belts and pulleys before working on the motor.
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
