Picture is now in pink and green with silvery letters, all channels and modes.
SOURCE: Sony FD Trinitron WEGA KV-24FS120 24" TV Color changes
Try turning down (off) the color during such an episode. If the image is tinted pink or green instead of black and white when you do this,you have either an intermittent short in your CRT (tube), which is terminal,or a gun drive problem, which may be repairable. If you're feeding it component instead of composite signal,it may just be a bad connection of the B-Y cable.
SOURCE: distorted picture on RCA LCD TV
I have the same tv. Had repair man come to my home in late april. Said it is the power convergence board. $225 for parts and labor I was told. Bad thing is part was supposed to arrive mid-may,then mid-june and now mid-july. He say's part is on back order. I'm actually going to contact RCA soon to find out if this is true. This seems to be a common problem with this particular T.V
it can be replaced with a t0220 stile case dioded 220k ohm go to nte look up and do a search on the rca part # 259638 search the web for the part.
SOURCE: color distortion and arched picture
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Solution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
Solution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
