SOURCE: changing toner in a konica minolta 2480MF
http://kmbs.konicaminolta.us/productsattachments/manuals/magicolor2480MFUserManual.pdf
check page 92-101 in pdf or 82-89
hope this works
SOURCE: After replacing black toner cartridge printer displays Drum Low
Ask you companey that surives you printer to look at it
The drum and the black printer cartridge are two separate items. You will have to purchase a new drum for it. I just had to do the same thing and it ran me $150.00 at Staples.
SOURCE: My Konica Minolta MC2300DL will not print. It is
You can change the 2300's menu setting to ignore empty toner cartridges and keep printing. There are 2 steps:
Step 1:
Press Menu/Select, then "right arrow" until you see ENGINE. Press Menu/Select again and then "right arrow" until you see TONER EMPTY. Press Menu/Select and you'll see STOP. Press "right arrow" once to change to CONTINUE. Press Menu/Select.
Step 2:
Press "right arrow" until you see AUTO CONTINUE. If set to ON, press the "Cancel" button and you're ready to print. If set to OFF, press Menu/Select, then right arrow to change to ON, then Menu/Select to enter. It will say "ON IS SELECTED." Then press the "Cancel" button and you're ready to print.
SOURCE: Toner problems with Konica Minolta 2450
very annoying message i agree - most likely caused by toner dust.
The printer uses a carousel to rotate the toner cartridges. Dust and toner can easily spill as the cartridges rotate. The error can appear at any time but seems to be most annoying after a paper jam or other error. It is also important to make sure that the cartridges themselves are clear of toner dust. Pay particulair attention to any copper contacts on the cartridge.
http://www.zinetic.co.uk/toner_refill/magicolor-sensor-errors.aspx
