SOURCE: Converting LP dryer back to Natural Gas
the gas dryer is one you need not have to change out the parts. just turn the orfice around, how and where? That would help.
SOURCE: How to convert from LP back to Natural Gas?
I have an old Kenmore dryer that I need to convert from LP to gas. I have the parts but no instructions. Can you please help?
Thank you, Roxanne
SOURCE: Converting a GE Profile Gas Range from LP to natural gas
GE ships gas ranges set for natural gas, with the LP orifices included, usually on a metal tab held with one screw right near the regulator (where the gas connects to the range). If the range was converted to LP, the person who did the conversion was suppose to put the natural gas orifices back in that holder. If they are missing, comment back on the exact model number and I can look up the part number(s) for you.
SOURCE: Want to convert from LP to Natural Gas
Typically, the only thing required is changing any and all jets since energy content and pressure are different. The only source for these is probably the manufacturer; check their website.
SOURCE: I converted my 40
I am having almost the same problem. Frigidaire told me to replace all 5 mixing tubes, ~$385, yeah right. They don't have the orifices itemized as an individual part, so no-one carries them, just the LP conversion kit. Another repair/parts guy advised me to drill out the orifices. Some other threads/blogs give the diameter to drill. Basically, since natural gas is 0.5 psi, you need a larger hole than your current propane orifices provide. Please speak up if you find out anything, I will try to do the same. Good luck.
