SOURCE: honeywell oil radiator
Press the *power button* once to start the heater on high power, continuous run. If left at this setting, the unit will run continuously on high power (1500 watts, 12.5 amps) and will not shut off until the unit is manually turned off.
Press the *power button* again, to change to low power, continuous run, (900 watts, 7.5 amps) and will not shut off until the unit is manually turned off.
Set temperature:
Press the temp/timer button until the temperature icon blinks. Use the up and down arrows to set the desired temperature.
The temperature icon will stop blinking and the current room temperature will reappear after the desired temperature is set.
The heater will turn off and on to achieve the desired temperature.
Set timer: (auto off)
Press the timer/timer button until the timer icon blinks. The hour display will appear. The auto off icon will also appear.
Use the up and down arrow buttons to set the heater operation time between 1 and 10 hours. This function will activate once the timer icon stops blinking. The heater will automatically turn off whn the times runs out.
Set timer: (auto on)
Press the temp/timer button until the timer icon blinks. The hour display will appear. The auto on icon will also appear.
Use the up and down arrow buttons to set the heater start time between 1 and 10 hours. This function will activate once the timer icon stops blinking.
The heater will automatically turn on when time expires.
Hope this helps!
SOURCE: We started getting fumes from
Either something has been accidentally spilled on it or it has a slow oil leak somewhere. Also, be sure it not to close to something that may produce fumes when the heater, heats it up.
SOURCE: noma ew7507ce manual
Timer is not identified.
Noma is a recognized brand name that is licensed to many different product manufacturers for a variety of different products including timers.
Check resources below:
1) Add a comment with clear description of timer, and/or post a photo on flickr and include link to photo
2) Open following link to see various Noma timers and download possible manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html
http://waterheatertimer.org/images/NOMA-logo-1200.gif
3) If you have different product than a timer, for example an oil-burning radiator or electric baseboard heater then re-post question on fixya with clear description of product for possible research and information
