If you're running a double wall oven as displayed here, you would need to replace the control panel in the front that has the green little ribbon cable on it to solve this problem, I actually imagine that that part unfortunately may not be available anymore, however you could call parts and check availability at 1800 626 2000 This is also known as the keypad assembly.
SOURCE: Upper Oven doesn't heat in bake or broil. Lower /Ctrl panel OK
check to see if both ovens are the same circuit if they are you have a internal problem with your upper oven internal circuits or damaged wirering contact a qualified service tecnitian
SOURCE: i have a ge double
Hi.
Check the thermal cutoff. Remove the thermal breaker from the oven and use a multimeter set on Ohms to test it. If the part reads open (infinity of Ohms, same as on air), then you need to replace the breaker
Here the part:BREAK THERML
The part is indicated with number 353 in diagram below.
If the thermal breaker is OK it will read zero Ohms or very low impedance. In that case the next part to replace is the thermostat. The thermostat also called temperature sensor or probe, is located inside the oven cavity.Test the thermostat in a similar way to what you did with the breaker. If the thermostat is open at room, then replace it.
Here the part:Oven Sensor
The part is indicated with number 332 in diagram below.
Here the diagram. Click on the picture to enlarge:
Note. I could not locate the exact model number in database, please call the part seller and ensure that parts correspond to the ones used in your model.
Regards.
Ginko.
