SOURCE: i want to know where i can buy a stanley Tre500 electric stapler
They will have what your looking for at your local Sears or Lowe's. If you go to www.bing.com you can type Electric Stanley Tre500 Staple Gun into the search bar and it will bring up some links for you where you can buy the product online.
SOURCE: Need manual for stanley electric stapler model
here is a link to the manual
http://homeappliance.manualsonline.com/mdownloads/f2624d76-9579-4c12-a9f1-22eab6ac3388.pdf
SOURCE: I have a stanley sharpshooter
First off, Carol, does 4502 mean anything to you ? If not, then disregard. The +/- refers to driver depth, which will be your power. If going to deep, turn to the - sign, not enough, + sign. Hope this helps you. If you know 4502, let me know what it is, you might know me.
SOURCE: I am having problems getting
Hi Rita,
Yes, the + and - adjusts the depth of the staple. You should check the setting periodically as it has a tendency to move as you handle the stapler.
Also, holding the nose of the staple flush and steady on the surface helps to drive them to the proper depth.
Hope this helps. If it does, I'd appreciate a 4 thumbs up, keeps me working... Thanks,
Handie Andie
