SOURCE: front loading wash machine
It sound like door lock unit is broken or removed from the door. Good luck !
SOURCE: Frigidare front load washer warranty
The usual factory warrenty periord on the Frigidare Affinity washer is 1 Year from date of purchase. You can find your Model number and serial number of your washer on the inside of the door. It is on a white label towards the bottom of the dorr.
SOURCE: washing machine is leaking
you can remove the front panel(3 screws across the very bottom lip) from there you wil gain acess to view the underneath, as the macine is operating to pin point where the leak is coming from
SOURCE: need manual
yes if you go to the "parts" section of SEARS.com and do a little search and if you have the FULL model # (some thing like xxx.xxxxxxxx) it usually on inside edge of cabinet if the door is open. they have most manuals downloadable
SOURCE: How to increase the water level of Front loading washing machine
I have used extra weight inside the tub. I have used bottle of water and also a plastic 2 or 5 pound weight.
