Hello, Concetta -
Did you mean to ask about a Proscan TV (not Proscar)? If so . . .
The information here may prove helpful:
https://www.eliztech.com/remotes/codelists/proscan-tv-codes-for-philips
Best wishes.
SOURCE: need code for philips tv
you can get the codes from the link i have given you. Download the file and it has the codes and user manual for you there are quite a few for philips... so be patient and you will get it:)
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/ge/rm24912-manual.zip&area=other
A "fixya" rating would be great for my time to get this info for you.
thanx
SOURCE: philips remote codes
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This
is the user's manual for a Phillips remote control. There is a list of
codes in it. They should be rather universal. There's also instructions
as to how to program it. I believe that there is a way to program it
without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4.
Press the Channel Up button repeatedly (up to 300 times) until the
device could be controlled changes channel. The red indicator blinks,
then stays lit. If you accidentally overshoot the code required, press
the Channel Down button to backtrack through the library until the
device changes channel. Pressing Channel Up changes direction to
forward again. Press and release the Mute button to install the code.
Hope this helps :)
SOURCE: Philips Universal Remote #CL034- Need tv codes.
I found that these websites should have all the codes and instructions for most remotes
http://www.xdiv.com/remotes/
or http://www.remote-codes.com/
let me know if this helps
SOURCE: need code to program philips universal remote
most philips universal remotes have the "code search" option this is done by:
1: Manually turn on ur tv
2:hold setup untill red
indicator stays on and release button
3: press and quickly release what
you wanna program (i.e tv,vcr,ect.)
4:press channel up repeatedly
untill your t.v changes channels(up to 300 times) if you over shoot the
channel change press down til it changes again.
5: press and release
MUTE to install the code.
SOURCE: Need a Philips universal remote code for Apex digital tv convertr
try going to this Philips site and using their universal remote control finder tool ...
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?tmplt=ePlatform%20-%20Philips&scy=US&slg=AEN&sct=REMOTE_CONTROLS_SU1&cat=REMOTE_CONTROLS_CA1&session=20100815184715_64.252.199.203&grp=SOUND_AND_VISION_GR&ctn=SRP4004/27&mid=Link_RCCodeFinder&hlt=Link_RCCodeFinder
