Problem in ADF it prints wrong mesure and copy vertically or horzintally the second problem : witheline among the page
SOURCE: Konica Minolta Bizhub 250 Authentication issue
What you require can be achieved though the "public access" settings. This will allow you to control what can happen without requiring a log in.
SOURCE: Print Booklets with Konica Minolta Biz Hub C650 Printer
Select Print, and then "Properties"
Layout Tab - select Print Type: Booklet
Basic Tab - Select original size and then size of PAPER to be printed. 11x17 is standard 8.5x11 book when folded.
Finish Tab - select saddle stitch.
Thats it, easy as pie.
SOURCE: Konica Minolta BizHub C451 printing red lines down documents
your imaging unit is damaged. call minolta guys to have a look it at and change it if neccessary
SOURCE: bizhub 250. error c2152
Check and make sure there are no jams by the fuser ie: bits of paper in the paper path.
SOURCE: The print margins on my Konica Minolta Bizhub c203...
Check and see if it does it on copies too. If so then your paper trays maybe out of center or your paper guides may be open. If everything is center and registration is correct, your print may be in the "Void Margin" this is an area around the page the machine will not put toner in. Konica Minolta Bizhub C203 copiers do not have an edge to edge print capability
